never had insurance :/
i rang up a couple companies when i first bought the car 3 years ago, after checking my records and type of car it was they said they wont insure it for me and that was it. never bothered with it again
dood do you fkn realise how stupid that is?
what happens if you write off a roller? or even just a newish merc/beemer
He probably thinks he is too good to have an accident.
Another thing is if someone hits you who doesn't have insurance and writes off your car. Good luck getting a cent lol
Cars don't impress girls worth impressing. It may score you a bj or hj from time to time however.
im pretty sure shes just sucking up..
this the one that got a 25% enter and tried her very best
Lol have to get stock solenoid. If u just disconnect and connect lines it will run unlimited boost
lol thought so, hrms
wtb, stock rb20 solenoid
wtf are you two on about.
The r32 does not have a boost solenoid. Only the r33 does.
Pull out the bleed valve and reconnect the hose. Not rocket science.
A single hose from the actuator to the turbo. Done.
Epic lol if you posted up a WTB thread for a r32 boost solenoid. May as well ask for headlight fluid.
Lol well I down a piece of shit r32 so I assumed it's got a solenoid. Chill princess Tricia
just had a stupid holden ute tail gate me then overtook me and got stuck behind a car infront and instead of waiting for the overtaking lane that was 50m ahead he pulled out over straight lines and sprayed rocks all over my car so i quickly floored it to catch up so i could get his number plate and abuse him just incase if my car got any big stone chips from it :angry: he shouldnt be hard to find he has personalised number plates and live in the same area as me. can you seriously get anymore impatiant than that?
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
