yeh leigh, i aint even turning it on.... gonna get it towed to the mech, but just gotta get some $$$ first.... so that means the professors are for sale... will put up the add in a few days :/
hold on. Why the f**k am i stressing?
i take public transport when i go out, and i would most likely take the territory on long road trips if im planning on going beach etc because the skylines a tad bumpy and loud, so this leaves the line for going to and from work etc. i work for my old man.. work exemption?
still gona have it for sale though
edit:
Edited by Mohsen
That shit you listed will take half a day to do.
Theres a reason why r32's are selling cheap and you have to be pretty silly to buy one and not expecting to work on it.
Go buy a Toyota Corolla if you dont want any hassles
Patrick, want to work on it and see if it take you half day to do...
And these above aren't the full list of things need to do...
Sorry to hear the motor may be gone, my advice, get another motor and whack it in, easy fix.
If it's bearings, except $5k upwards as you'll need to do it while you're at it...
good work
did you get a new photo on your p's
ive managed to keep all my licence photos
leaners
p's
full licence
full licence
its ace
I had my P's one for 7 years, the made me get a new photo last license renewal :(
I remember someone mentioning driving into guardrail at 90km/h and the damage on 31 was bugger all.
That's my first R31 you're talking about. 90kmp/h into a guardrail did this (no, I wasn't driving):
It was still drove home from country VIC and sold as is for $1100 :thumbsup: It previously looked like this:
I loved that car.
R31's are excellent cars, nearly indestructable, plenty of power, cheap and reliable. Just what a P Plater needs.
yeh leigh, i aint even turning it on.... gonna get it towed to the mech, but just gotta get some $ first.... so that means the professors are for sale... will put up the add in a few days :/
When/if mines goes I'll be putting a 34 neo in there, $1800 + install. Pickup a little more power at the same time.
Building an engine for a street car is like masturbating with sandpaper, somewhat enjoyable at the time. But later on when you goto use it again, its gonna hurt like a bitch.
Its defiantly from the bottom end? Something hasnt come off the clutch and its knocking..? Pulling straws I know, but you can only hope...
Mohsen or Grant... http://www.carsales.....aspx?R=9513923
Read more http://en.wikipedia...._3_Series_(E30)
If I want it to be 100%, I'll need to piss at least 10k on it.
I need to piss the dynamat off, previous owner had it covered in boot including 4wd and HICAS ecu... Stereo wiring to be binned, sound deadener removed, louder exhaust required, new wheels, 100k service, rip the hicas off, list goes on...
LOL! @ Dynamat sound padding shit.
Why did you buy the car if it needed so much work?
Sidz? 0.o
Skidz Yo!
:laugh:
set it high, trawl for offers
mm ae86 ey...
so just to clarify, the rb20de minus T option is a no go, correct?
Yeah AE86 boys want top dollar for Corolla's.
Takumi Tax!
if i was a p plater.... 4age ae86/ke70/ae71 or R31
mx5's are fkn cool... BUT only cool once slammed and fitted so hard that petit would actully bar up if you drove past him
R31 would be nice for a change.
I want Kriss R31.
sudden infant death is all the rage these days with the muzteks maccas employees?
LOL!
Skidz Yo!
edit:
Looks awesome!
do you mean rb20det and remove the turbo to avoid the power to weight rule ?
if this is what you mean - if you remove the turbo it is still a gtst skyline and still registered as turbocharged from factory etc, so its technically over the power to weight rule. ie they dont weigh your car and then dyno it to see if you exceed the power/weight rule, they go off factory specs. so you could get a 6litre v8 with a blown motor that makes 10rwkw and its still be over power/weight (from the factory specs)
Guest
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
