But it's yellow :s
mines yellow and looks alright
stands out too
i really like it in yellow, looks great
theres something i really like about it
and dont really like 7s
agree MR is the ideal model
i had a run with a X MR last night on sydney rd was pretty fast but pulled away still :)
yep find an 8 MR FQ400 for 27k :D
or an FQ400 for that matter anyway
i only know of 3 that are in australia atm
Euro Car Owner = Apple Owner
Jap Car Owner = Android Owner
Holden Owner = Nokia 6110 Owner
lol
new fog lights, what ya think?
wow, square lights. way to clutch onto that 90's umbilical cord. Are those the ones from a series 1.5?
stands out too
looks like the morning after results of eating a shload of corn cobs. Deja vu?
yo dawg, i herd you like high alcohol content. so I got you some methanol. 100% nyukkuh.
But yeah, arrak isn't strong, it's just shithouse homebrew crap that's badly distilled, hence making you feel like you participated in some two guys one cup action. Hell even properly mass manufactured arrak that we get from Sri Lanka (one of the benefits of a cultural history of being an arab trading port in the indian ocean) tastes like ass cos of the raw material content, not the alcohol percentage.
shit aniseed bro
looks the good billy how'd you mount em? i gotta work out how to mount my indicators to my bar still thinkin ill sikaflex the kents
indicator ~~> parker relocate job.......
doooo eeeeeet
Slagging off 90s cars is getting old shan :/
Suck on deez nuts. Your 90's car is gettin old foo.
just sayin, a good mesh insert with a nice round projector foglight would look way nicer. Especially cos the headlights on his S2 R33 is nice and clear with very little diffusion, then you got these frosty white n orange foglights which are diffused like a motherbitch, goin "BLAM! how you like this blast from the past?"
it's all about sticking to a theme. all diffused 80's style = cool, all clear late 90's style = cool, half and half = slummin
  • Like 1
yeah, I like how those foggies fit into the vent tho, maybe pull the frosted plastic off and replace with clear perspex and a bright white/yellow LED array behind it? Would look tits. Would also set it apart from a sedan front?
a 25 and 26 both making 245rwkw, the 25 makes it earlier, has more response and a better power curve
go figure eh :-)
twin vs single
the main diff is the twins seem to keep flowing more in the top end past 7k
Guest
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
