It's an MPS though. Would leave the Accord Euro for dead.
Yeh my mums got a mazda 6 MPS in red, 06 i think it was they bought it brand new its quick car i LOVE driving it much more daily friendly then mine haha sunroof open cruising, and anyone that says the interior looks bad O.O wtf? awesome leather seats n shit and dash looks mad snake (maybe interior is a sport option?)
Nice drive to Marysville today. 3 of us got pulling into drug bus in Lillydale. RX7, silvia and myself and didnt get defected, infact all the cops admired our cars and let us on our way haha best :thumbsup:
That's surprising considering the TMU moved there...
was bored and thinking bout jobs, so i decided to check out apprentice mechanic wages....
googled it and $7.05 p/h 1st year.... faaaaaaaaaark that! its the same as cheffing ffs! and that's BEFORE tax
do they even tax people on that ?
I thought it came with 2 attachments. 1 h pattern and 1 sequential
Not sure, never seen anything mentioning 2 attachments...the 25 has a switch to change from H to sequential, can't see it on the 27
http://www.logitech.com/en-au/gaming/wheels/devices/5184
but there's a shift pattern on the knob, so they might've ditched sequential
you wouldn't believe it but they do....
chef apprenticeship is $7.40 p/h 1st year and the government stick their filthy hands in your pocket for roughly $2 of that...
then they have the nerve to run adds telling you to learn a trade for your country :down:
Shift your way
You can quickly select the correct gear with either the six-speed shifter or the F1-style paddles.
Ditched the sequential...Not really an issue when I'd be mostly using it for F1 anyway, so paddles are the go there, and any other racing game I played you'd either be in a supercar using paddles, or the H pattern....$5-$600 for a toy steering wheel is a bit steep though..
You'd get pretty much all of it back at tax time though..
Keep in mind, everyone, that ester based oils CANNOT be used with alcohol fuels.
I have had a Motul rep in my shop telling me if we run E85 or Methanol that we are not allowed to run their oil as it will damage it.
whoh mind blown. Any chance you were using Motul 300v with E85 Hamish?
Guest
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
