You'd get pretty much all of it back at tax time though..
if you survive till tax time :/
i only made it cos i was dj'ing as well at the time
whoh mind blown. Any chance you were using Motul 300v with E85 Hamish?
nah, i have always used turbolight for that reason... changed every 5000 or before due to trackdays
you wouldn't believe it but they do....
chef apprenticeship is $7.40 p/h 1st year and the government stick their filthy hands in your pocket for roughly $2 of that...
then they have the nerve to run adds telling you to learn a trade for your country :down:
lol make more @ mcdonalds.
ah k, i would have ran my water/meth on 300v and would have owned myself haha
probably better not to do that ;) i have mentioned it many times in the past couple of years mang....
Domestic electrical apprentices are on about $7, $3-350 a week gross....
f**k that's harsh.... you reall need to be living with parents or a sugarmomma
yup.... that haunted me every day during my apprenticeship :(
I'll be moving into my place in the next month or 2 I'd say lol...good timing.
Should be able to manage though
and brand new logitech G27 for $335... RRP $600. hmmmmm
25 has H and sequential which is why it always breaks for some reason,
27 has just the H, but remember you got flappy paddles for sequential + more buttons for binds on the steering wheel and f1 rev lights
Holy farkin shitballs $7.40? Is that even minimum wage?
totally legal... fkn unbeleivable isn't it....
not to mention that fine dining restaurants pay you that wage for 38 hours, but make you work ~80
now clearly that's not legal but it's just how it is if you wanna work in a top restaurant
Remind me not to work in hospilatity
Where where?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=130471555313
says more than 10 available but already 14 sold just today....Was gonna think about it before I bought 1, but now I think I better just buy one before they run out, coz the other listing from the same guy is $490 or something like that
Guest
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
