Oh man, my car does that too! When it's really hot outside the car won't start up / idle properly and I have to keep feathering the throttle for it to keep running. Does my head in.
Yeah that's it.
How long have you had this problem?
What have you tried to solve it?
its the rmit in carlton so im guessing thats tafe
woohoo
anyway. some flamin mongrel broke into our front yard at work, helped themselves to our truck batteries, GPS and a shitload of tools
must have been midgets too, the hole was so fkn small
mohsen theres both uni and tafe there but mech engineering is at uni, I used to go there. I hope unlike me, you'll spend your time in lectures/tutes and not on the 3rd floor at the cafe playing pool.
Oh and for quality rmit chickitas, hit the arts/music/business etc buildings across the road :thumbsup:
f**k yeah..
Just had a Compact Fluroescent globe (energy saving) explode. Scared the fucking shit out of me!
Supposed to vacate the room because of the mercury, but it's a bit hard in a 1 bedroom apartment lol
Yeah that's it.
I've had the problem ever since I bought it 2.5 years ago. Basically when it's hot I know to keep my foot on the accelerator lol. It coughs and splutters for the first 30 seconds or so and sounds like it's running on 5 cylinders lol. It wants to stall desperately, but then it comes good.
I have a feeling it's the ignition module. Any suggestions?
those big halogen out door ones are LOUD. threw one into the skip at work, though its just gona crack.
throw it in, BANG! fkn shat a brick
in other news, had person with me today in my car, they go to to fiddle with the centre vent (they wanted the ac on) and the whole thing just crumbles....
now to buy a secondhand one..
the car should start the same if its hot or cold
do you mean the water temp is cold ,30deg ish and its hot out side 35deg and it doesnt start?
or after driving it, in summer, when you goto restart car whilst still hot, it doesnt start ?
Chatted to couple of buddies, one reckon it could be IAC or AAC or whatever valve but you mentioned ignition module...
May give it a go.
Bit of both, just struggle to start on hot weather even if motor haven't started in a day or 2.
One time, started it up no worries, drove to work, 7 hours later it struggled to start until I pumping the acc pedal for it to start.
Guest
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
