the lovely thing about skylines is that it could be SO MANY things..
Such fond memories of driving in the middle lane in heavy traffic at 100km/hr on the ring rd.. down the hill after Sydney rd.. ***STALL**.. sheeeet! Trying to restart and change to left lane safely at same time... while rolling down the hill at 100km/hr.. FARK it's almost funny now.. lol. Managed to get it to start before the bottom of the hill.. Think I lost a few years off my life tho..
OH PS that one was from dodgy AFM
by pumping the accel all you do is open the throttle body to let air in
so if the AAC is toast or gunked up etc then it may not let enough air in, and opening the throttle body, effectivetly does this
iac - idle air control
aac - auxiliary air control
those big halogen out door ones are LOUD. threw one into the skip at work, though its just gona crack.
throw it in, BANG! fkn shat a brick
in other news, had person with me today in my car, they go to to fiddle with the centre vent (they wanted the ac on) and the whole thing just crumbles....
now to buy a secondhand one..
Those can be epic fun. Me and a couple mates have smashed a few of em across eachothers heads after losing bets
only on starting or when driving? accelerating or slowing down? 2 yrs, did you post in the tech/maintenance section yet? :P Lots of ppl have these problems with stalling
unr33l if you're bored u should have gone to meeting!
Dammit didn't think of that!
we used to hit each other with those plastic cricket bats. we wore shin pads for safety though.. even tho we smashed each other over the arm, back etc
damn we were stupid
my car struggles on start up too, all i do is pump the pedal once though, all good on idle
Stalling in my experience could be.. fuel pump, fuel filter, fuel lines, coil packs, AFM, spark plugs, AAC valve as above.. lol there's more that's the short list. Bloody Nissan imports with their constant 'issues'...
I know!
It has been doing my head in for couple of days, but I have trouble giving it up and get something 'sensible' cos it consists of me better off cutting my penis and balls.
mmm watch thread enticing me to buy watch >_<
Anything worth getting around the $500 - $1500 mark?
Some ive stumbled across, but i got no idea whats good :domokun:
Longines L1.647.4.72.3
TAG Heuer Carrera Mens Watch WV2116.BA0787
WV211A.FC6202
Raymond Weil 2710-ST-20001 Freelancer
RADO Integral R20784759 - WW
pat- TAG Heuer Carrera Mens Watch WV2116.BA0787
omfg theres an na type x 180 on egay WHY DOES ALL THE GOOD SHIT POP UP WHEN YOUR CAR IS FOR SALE..
and when it sells its all sold and theres nothing around
Edited by Mohsen
Give me your airbox. Ill give you an Apexi airpod for it.
mohsen theres both uni and tafe there but mech engineering is at uni, I used to go there. I hope unlike me, you'll spend your time in lectures/tutes and not on the 3rd floor at the cafe playing pool.
Oh and for quality rmit chickitas, hit the arts/music/business etc buildings across the road :thumbsup:
cant go wrong playing pool mate
got me through 2 years of mech eng at rmit city :P
http://www.skylinesaustralia.com/forums/topic/350732-r32-skyline-side-window-louvres/page__pid__5630731
lol @ someone paying $250 for these! You could make the light up panel for cheaper than that. Ever seen these before Shan?
but none of those have a sole part in cold/hot start
all of those are used in engine oepration, but dont have a sole purpose in cold/hot start
ie if the AFM is toast the car would do other wierd shit
likewise for fuel pump, throttle body, injectors, coils etc
Quality
All these people whinging about idle/start up problems, my car must've been solid, never once had any issues with anything like that..
none of my AC vents have cracked nor has my dash bubbled up. It has been sitting outside for 5yrs in the sun and its good as the day i picked it up.
Although mines a 1993 October, last build date, so they may have made some improvements by then?
Hopefully the dreaded dash bubble doesnt emerge!
Guest
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
