lol but its so easy to fall behind, was for me anyway :unsure:
serious question - where can i get some police sirens/lights?
LOL a few weeks ago, 2am in the morning coming back from fishing, i had a little blue flashlight, anyway, car infront so i start flashing it from the front, peeps pulled over
was hysterical
pat- you know how you see news of the face of jesus popping up on things etc, well imagine if a bubble pops up looking like this guy
lol yeah we used to have em on a 318i pulled heaps of kunts over even went as far as going up to them asking for their license...
is there some kinda kit you can get that makes your headlights blink in that sequence? i dont want the blue and red
My ex back in highschool, her brother fitted out all the cop cars...brought home a set of the little dash lights the unmarked hwy cars use...that's what you want, they were bright as f**k lol
You know you can get charged for impersonating a cop yeah? lol
My car has the starting problem when the car is cold, I.e it has been sitting outside all day and the outside temperature is 35ish plus. The hotter it gets the worse the car starts. Having said that it has happened to me a couple of times when I've driven the car and left it for ten minutes, then come back to start it again.
Once it was really hot, like 40 degrees outside and the car wouldn start at all. Was turning over, but not firing. I left it for an hour and came back and it eventually fired up, but it was a pain in the arse.
And yes, it's been over two years and I've never done anything about it. Why? Because I am one lazy f**ker.
Bit late for that Adam, I ended up watched some DVDs and had short sleep (2 hours).
The GTR is apparently fine so dunno why I sometimes have trouble starting it in hot weather ( sometimes have to pump the accelerator pedal) but it's fine in colder weather like today.
Hot Start Enrichment is overfuelling it.
lol yeah apparently its like a 5K fine and your car impounded. but i think that's only if you have the blue/red lights
Not only charged, but completely arse raped!
Do it man! I'll make sure to give my cop mate your rego so he can arse rape you LOL
http://www.skylinesaustralia.com/forums/topic/350732-r32-skyline-side-window-louvres/page__pid__5630731
lol @ someone paying $250 for these! You could make the light up panel for cheaper than that. Ever seen these before Shan?
first set ive seen forsale though
Quality
All these people whinging about idle/start up problems, my car must've been solid, never once had any issues with anything like that..
haha mine never had starting issues :D
none of my AC vents have cracked nor has my dash bubbled up. It has been sitting outside for 5yrs in the sun and its good as the day i picked it up.
Although mines a 1993 October, last build date, so they may have made some improvements by then?
Hopefully the dreaded dash bubble doesnt emerge!
i replaced one side vent and never had bubbled dash 89 model :P
isn't that what you want?
haha this is what i want! the ones on the silvia
YBDOG4
Guest
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
