Power steering is gay. If I had it, you could take it. But I don't :)
MR2 powersteering is used on track car builds cos it's full electric. plus it's bang for buck better than a lot of aftermarket units. pretty easy to control on and off etc via in switch cabin. Turn it off to conserve power, turn it on for quick maneuvering (ie, drifting/racing).
road going MR2's couldn't care less, but when you remove the power steering pump and all that shit off an RB/SR/1J/2J there's a substantial improvement in engine power. Then bolt on electrical MR2 pump and instant partytime. Weight loss + response is awesome. lotta Mazda/VW/Datsun/Nissan/Toyota guys do the mod.
Reason you don't have powersteering in your car is cos it was a very expensive option, and a lotta peasant spec owners didn't choose it when they ordered the MR2. The reason it's electric is cos your engine's in the back, and your driving wheels are in the front. It's cheap for us from factory cos everything's in the front. Make sense?
lol I had 3 very long cracks through my dash after parking it in the heat one summer.. bitch to swap over :\ I recommend not pushing your luck with that..
those louvre things are cool but what the fu..gly colour...
justjap have aircon vents, not sure if they still have stock but for the time u spend looking for them and find nothing, might as well spend the $100odd and buy them brand new
R-Spec: just go for a drive, bound to find some right behind you within minutes
haha its been going strong for 5yrs. Bring it on 2011 summer!
Does a rear strut brace on an r33 make a noticeable difference? I was pleasantly surprised when I put the front brace on the car but I'm yet to put a rear on. Any opinions?
dunno, i know on r32 suspension they do shit fk all. (as expressed by sydneykid)
Yeah, i noticed an impressive difference with the front strut brace on. Just not sure about the rear one given i've seen some posts from SydneyKid which states they do absolutely nothing.
So you noticed a difference with the rear brace Grant? Can you give some details?
went to pick up a little dough mixer in my car today, at the lights, cop pulls up next to me
im thinking, oh f**k my life. (i had a paper from the boss so i was all good, just hoping they wont pull me over and defect me for the tee and the tt)
so.. i cant resist the temptation and look to my right to see if their looking, whattdya know, their looking.
crack a sheepish smile and get a nod back. that was it..
lawls. Loose the Tee and that rice turbosmart sticker in the engine bay.
Yeah, my old gtst came with rear brace not front for some reason, when I removed it it felt sloppy around corners, with that in place felt much better, then along came front brace. That was with standard suspension btw.
You think a letter from your boss supersedes the law?
You really are a douchebag
vicroads website says im automatically exempted if a letter is written by my boss bla bla with business hours, telephone numbers and shit when i drive the car for work
have to keep it on you at all times, and of course no ridiculous hours like 9-1am etc i got 7am-5pm thats when i go to and from work, after that its cruising like a hard kent in the territory lol
Guest
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
