I never had issues with my previous GTR and my current GTR both has aftermarket turbos and noisy exhaust (granted that I don't drive 32R much).
It sounds like you're after stockest of the stock. Good luck finding one.
consider yourself lucky then. i dont remember the last time i took my car out without a cop atleast eye balling me, while im shitting bricks hoping he doesnt turn on his sirens. cbf anymore wayyyy over it
australians need to get some knackers and start protesting about shit they arent happy about like 90% of other countries in teh world.
i want my donation back $20+ a month is a lot of money i could use elsewhere.
on another note, i fkn hate labor governments and i'm never donating again! theiving scum.
thank god i voted liberal and can blame everyone else who voted labor
Let's be friends.
Now to invent fanciful deductions to offset the levy mwahaha
sweet, I'll go through it
im still keeping the M3 and a 34R as options but atm leaning towards the 33. fml.
If the 34R is a realistic option, I wouldn't bother with the 33R...
Washed car and touched up stone chips and re did clear coat on front lip :)
Took a few pics as well:
inb4 "MOAR LOW"
Needs more low!
:D
+1. Labor can suck my wang.
You want Julia Gillard wrapped you?
:laugh:
As for the orange wheels, I wouldn't be using supercars and full body decaled drift cars to convince myself something will look good, because they won't look like that on your car
true that.
Pat, your R32 is not a GT3... :laugh:
Go White or Bronze for a clean look.
If you want a tough look go Black.
never said its a gt3, just admiring the colour scheme :P
white, bronze, black is boring, stop having a boring life. /slapchop
Fk it, ill stick with my offset fail drifteks :domokun:
Guest
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
    • with the car running (runs fine when temp is cold), I unplugged the MAF and the car stalled.  I have already cleaned it a week ago.  I unplugged the O2 sensor from the left side of the vehicle, and the car was still running.  I let it idle for about 5-7 minutes and shut it off, to see if it would restart, and it did not.  It cranks but doesn't start after engine temp gets up to normal range.   I still need to look at the coolant temp sensor, is this one at the top or bottom of the radiator? Or is it one of the sensor threaded into the T-stat housing?
