Don't remembered shooting someone?
its a simposons quote mang :) when jasper didn't understand what was being said to him
got a bit of a gangster movie marathon going
godfather trilogy
goodfellas
snatch
lock stock & two smoking barrels
donnie brasco
the departed
carlito's way (now playing)
Casino
The Untouchables
godfather trilogy 1&2 - win
goodfellas - win
snatch - win
lock stock & two smoking barrels - win
donnie brasco - win
the departed - fail
carlito's way (now playing) - win
Casino - win
The Untouchables - decent
the departed get's a fail because although it is a decent enough film, it is a shithouse remake of a better film
it was originally titled "infernal affairs" and is a hong kong film from ~2002
if you are watching snatch and lock stock, dont forget layercake and rock'n'rolla
well i'm staying rb25 for a while.... got a great deal on a "70,000km" stagea motor that's in a1 condition, so that should be done in the next couple of weeks
but as a stag motor it'll be a series II system so i'll need new splitfires... who's doing the best deals atm?
goodfellas - win
snatch - win
donnie brasco - win
the departed - fail
Casino - win
they movies?
nengun, but if you cant wait for delivery there is a kudo motorsport thread for them and will prob get them later on in the week
Got mine for 479 delivered still being processed though
so no dirty 30 then?
Guest
    • Maybe but doubt it, when I jacked it up it was creaking in the j arm again. The inners are all good, I inspected them. Remember that also it did fix the problem but temporarily.
    • Could be the other bushes. The inners.
    • Once you lose the adjustable bushes, you have almost no adjustment at the front for anything that matters. You can only wind so master caster at the front, and ~7° is fine. You won't have choice of front camber. If you only have rear camber arms (ie, do not also have adjustable upper tension arms), you shouldn't change their length very much, because you will introduce bump steer. And, you will struggle to find a workshop that will be capable of doing all the adjustment work necessary to simultaneously achieve a decent rear camber number, get the toe right, and minimise bump steer. I would guess there's probably 8 hours of work there. So, stockish rear camber is fine. Although, keep in mind, that stock camber, by number value, does not mean stock arm length when the car is lowered. You will need to lengthen the RUCA to get back to stockish values and that will require the tension arm to be lengthened a little also. Without any other guidance, any change made to the RUCA should have the 2/3 of the same change made on the tension arm. But that is only a rough rule of thumb and the relationship might not remain linear across a wide range of adjustments. And it might not also be as close to minimum bump steer as you could achieve if you did the bump steer measurement and adjustment properly.
    • Well it does have a motor with the same DNA as an Accord V6 motor. The J30A is a successor to the Tiger rice cooker C32A motor found in those cars.
    • FD RX7 I would probably marry if legal R32 GTR is toughest NSX looks like it's made from leftover Prelude and Accord bits
