lol i figured you wouldn't want front camber arms for the rear dude ;)
billy's wheels are the same specs as my fronts (which is why i remember them) and his fit with a 20mm spacer and camber :)
also the fronts can be pulled to wherever you need... oh wait, you has fibreglass... how much further out are your front guards?
Kris where bouts did ya buy the t51 from brah?
lulz @ oilcooled only turbos. hey bros apparently they invented coolant a while back. apparently it's all new age and magical at getting to the right temp fast and cooling down quickly.
Fair enough,
I'm pretty happy, sold it in less than a week and got a great price for it!
That's great Mark. I'm gonna be selling mine soon. How many k's did yours have and how much did you get for it? (if you don't mind me asking of course).
lol i didnt say it would fit easy :mellow:
how'd u do it goin up a driveway or somethin?
I'm just pissed off, have been all day!!! f**king shit f**k ahhhh happened last night leaving my gf's. Reversing out of the stupid altona meadows driveways. Tyre pulled it in nice, having no luck fixing it atm :( now it just looks ridiculous, I've made a mess of it!! Sigh
Guest
    • Maybe but doubt it, when I jacked it up it was creaking in the j arm again. The inners are all good, I inspected them. Remember that also it did fix the problem but temporarily.
    • Could be the other bushes. The inners.
    • Once you lose the adjustable bushes, you have almost no adjustment at the front for anything that matters. You can only wind so master caster at the front, and ~7° is fine. You won't have choice of front camber. If you only have rear camber arms (ie, do not also have adjustable upper tension arms), you shouldn't change their length very much, because you will introduce bump steer. And, you will struggle to find a workshop that will be capable of doing all the adjustment work necessary to simultaneously achieve a decent rear camber number, get the toe right, and minimise bump steer. I would guess there's probably 8 hours of work there. So, stockish rear camber is fine. Although, keep in mind, that stock camber, by number value, does not mean stock arm length when the car is lowered. You will need to lengthen the RUCA to get back to stockish values and that will require the tension arm to be lengthened a little also. Without any other guidance, any change made to the RUCA should have the 2/3 of the same change made on the tension arm. But that is only a rough rule of thumb and the relationship might not remain linear across a wide range of adjustments. And it might not also be as close to minimum bump steer as you could achieve if you did the bump steer measurement and adjustment properly.
