Was trying to find racepace today.. driving down the road.. where is it? oh 10 gtrs right there out the front.. i figure that must be it :D
Got quoted about 600 for 100k service with cam gears put on (with my parts I already have) water pump fuel filter and all the shit. What you guys recon?
nah good show...
bear grylls enjoys drinking/bathing in his own urine way too much
lol yeah he's nuts. good watch though
chasers are getting more and more common around my area. and the more i see the more i dig...
trsbhdrtbyhstehbaet5h35gh3!!#@$#$%^^$#
Considering all the things need done at a 100K service + your Tomei Cam Gears / Water / Fuel Pump going in...
You know you will get a great job done.
I expected a tad more from Racepace, but $600 sounds reasonable.
Yeah, they are nice cars!
simpsons.wad
Hahaha!!!
I remember I had that.
The graphics look so pixeled.
the 600 is just labor though all my parts you think its worth it?
So is it labor 'just' to install the parts?
What about all the oils / oil filter etc..?
we've discussed this...
labour is an ESTIMATE to begin with...it might balloon if ur engine needs more maintainance, ie seals and gaskets, that need to be replaced. its a 13 year old car. this is bound to happen.
plus all your oils and lubes because they should look over the whole car, not just the engine. gearbox, diffs, transfer case. ALL of these need fluids and they all cost money.
i told u GTRs were expensive to keep before u bought it :P
including cost of ur parts id still expect around 2k. just like i told you to expect after seeing my 100 000k write up! :P
From what others have said its a prick of a job, $1100-1300 all up is the going rate.
Yeah right...
I figured there was more than just labor to add to the service...
haha nah. my car needed new brake pads as well :P but what richo said...its not an easy job and it takes a lot of time. a timing belt kit alone is 400 from just jap. water pump retails around 180.
ever had to do a 100 000 on a gtr dezz? cuz its all fairly standard stuff. theres a bit more to check what with the 4wd system than your average gtst. 0.o
i was charged $600 to replace timing belt water pump and flush/refill radiator coolant. parts + labour
if that helps...
they didnt flush and change any of your other fluids? thats strange.
Guest
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
    • Ah, to clarify if the car has already been tuned and has been modified and you want to go from a oem cat to a 100 cell or decat or vice versa.Are you saying that the car doesn't need to be tuned after a cat change if it's already been tuned?
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
    • That's the thing, they still add it and it makes fuel cheaper, implying adding 10% of it drops the cost of 91 by what, 5c a liter? I remember when it was barely half the price of 98. Because you know, 85% of what is in the fuel is way cheaper than 91 fuel is by volume.
    • Auto electricians that do repairs on automotive AC systems can source service kits. I don't know where they actually source them. I do know that there is one available for the R34 comp that I would need it for. If you have to pay someone to dismantle, clean and do needed repairs and fit kit contents, then you'd probably end up spending a good fraction of the cost of a new one. I would not be paying for that, because I would be doing it myself. My mechanic (bro-in-law) will happily source what is needed. Back in the day (like in the 80s and 90s), rebuilding an AC compressor was the standard approach, same as for starter motors, alternators, etc, because new replacements were v. expensive. After the China manufacturing boom and the rise of the disposable approach to everything, people just started throwing broken/worn stuff away and not rebuilding things.
