who installs anchor points? i need to get some put in the E50
is it a panel shop?
just do em yourself. get the right bolts and parts from nissan (like $10 bucks from memory for maxima ones)
there's some uglay ass and stock r32's in that bunch. canadians seem to have the most win out of all that, guess they've got US spec stance and Japan spec cars.
Yeah I know,
Hope mine looks decent.
AUS, Canada, NZ and Euro seem to love their R32's.
Canada has good stance NZ has good drift pigs LOL!
i was going to get max to do it... dunno if he has time at the moment, as always hes busy non-stop with his restorations.
might pop it up on the hoist and see what i have to do... if its as simple as welding a couple of those bolt plates in i'll do it myself.
I complied a few cars and all we did was tap a thread into a structural part and bolt a hook into it. then again they already had allowances for mounts on the chassis. Depends if you ahve to reinforce the area. Ask your compliancer, they should know.
nah r33. its a skyline. it looks better than an R32 GTS, looks heaps better than an R31.
i know its gona be slow n shit but mehh...
would look tops resprayed in the red thats on 350z's with pulled guards, GTR front bar. S2 grille + headlights and old school meshies. sitting nice and flush.
fuck off. you're going full retard if you waste a cent on an N/A R33. Everything you spend on it should be unboltable when you want to resell it (and you will, no one ever gets attached to an N/A R33). This means no respray, and no pulled guards. Stop wasting money, and living pipe dreams.
LOL!
Worst Skyline ever made.
why not go r34, it shits on all the other models :laugh: .
on another note its such a nice night i can hear all the fags trying to do burnouts in there commodores, i hope they lose there legs because there cars sound sooooo shit.
where u live ?
f**k off. you're going full retard if you waste a cent on an N/A R33. Everything you spend on it should be unboltable when you want to resell it (and you will, no one ever gets attached to an N/A R33). This means no respray, and no pulled guards. Stop wasting money, and living pipe dreams.
i said it would look tops.. i didnt say i would do it! :D
nah its just gona be a decent set of wheels and a GTR front bar(i hate the gts/t fronts)
lol gtr-boy you'd buy the farken heavy slow n/a R34 or the GT-R only without ever havin driven the other models? you should stick to your hilux :huh:
R34 GT-4 + RB26 = 4 door GTR
drove an auto R33. and the hilux is just sitting there. just want the damn thing gone. got it listed for 3k
R34 GT-4 + RB26 + turbos + intake + front pipe + flywheel + clutch + wiring loom + ECU + brakes + diffs + exorcist + hub assemblies + brake booster + gearbox + ATESSA controller + dreams + G-sensors + radiator + radiator support + hopes + bumper support + bumper + front guards + rear guards + respray + bonnet + instrument cluster + GTR dash insert + dash mounted gauges + fuel pump + fuel regulator + water pump + oil pump + alternator + starter motor + prayers = 4 door GTR
Guest
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
