makes sense. my mechanic did EVERYTHING on the car for me. ordered and fitted parts, flushed and changed all fluids, filters and spark plugs. made sure everything is working the way its meant to. im happy with paying that much for a job well done.
why pay someone to do something you can easily do yourself at home :thumbsup:
i do oils, plugs and filter every 5-7Ks anyway. brake pads take me 20mins to change over
if i had the right tools i woulda done eveything else myself.
but hey if you dont mind paying nothing wrong with that :cheers:
lol think u could take on clutch, transfer case, brake, power steering, gear box and front and rear diff fluids, flushed and replenished rimon?
sounds like a headache to me. better that those who are qualified do it :P
Thanks for the stories :) sounds about right then! Not sure who I talked to at racepace but a nice bloke as well
And yeah, I basically do my plugs / engine oil and basic stuff but rest CBF.
if you provide a hoist it shouldn't be a problem, surely you know how to use a spanner..? :P
I live in apartments.
The amount of space i have to work in, is basically the size of a GTR. It just fits in the carpark dimensions as it is.
So clearly not going to happen.
The labour for all of mine was around $300 - so the fact it would have literally taken me ALL day to do it in such a confined space, that's just how it goes for me.
I've done my own services in the past etc, but sometimes it's just not feasible as time is money.
usual rate is about $25 an hour, so he spent 3 full days working on your car?
What crack have you been smoking? The going rate for labour is normally $80+ per hour, they probably pay their workers less than $25 per hour but I don't know any stupid enough to charge so little.
When are we playing again Kris? :P I came pretty close to beating you last time. I'll admit you've got serious skills though.
I will whenever you wish to die next haha. Tonight?
Get it dezz. It's a bit different but when you sus it out you will love it
Guest
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
    • Ah, to clarify if the car has already been tuned and has been modified and you want to go from a oem cat to a 100 cell or decat or vice versa.Are you saying that the car doesn't need to be tuned after a cat change if it's already been tuned?
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
    • That's the thing, they still add it and it makes fuel cheaper, implying adding 10% of it drops the cost of 91 by what, 5c a liter? I remember when it was barely half the price of 98. Because you know, 85% of what is in the fuel is way cheaper than 91 fuel is by volume.
    • Auto electricians that do repairs on automotive AC systems can source service kits. I don't know where they actually source them. I do know that there is one available for the R34 comp that I would need it for. If you have to pay someone to dismantle, clean and do needed repairs and fit kit contents, then you'd probably end up spending a good fraction of the cost of a new one. I would not be paying for that, because I would be doing it myself. My mechanic (bro-in-law) will happily source what is needed. Back in the day (like in the 80s and 90s), rebuilding an AC compressor was the standard approach, same as for starter motors, alternators, etc, because new replacements were v. expensive. After the China manufacturing boom and the rise of the disposable approach to everything, people just started throwing broken/worn stuff away and not rebuilding things.
