go to hillside exhausts in furntree gully they have a $100 thing where they put temp exhaust on you go clear EPA, then they wack your old system back on :) they had a 32 exhaust i think, but had to slightly modify it to fit my 33 but because jay is a champ didnt charge me any extra
SWEET.
So taking immaculate conception into account, and IVF
It's possible ye?
what are you on about?
lol, their car got trashed and they offered me a reasonable price for my car so yeh, just need to remove the boost tee and get a new bonnet lever handle for road worthy.
is that the one were he breaks his leg tryina kick down a tree? lol
that guy was and pretty much still is my idol eventhough he cant act
That's the one...cuts it to the bone, don't think it's broken though coz he keeps walking/fighting
Was trying to find racepace today.. driving down the road.. where is it? oh 10 gtrs right there out the front.. i figure that must be it :D
Got quoted about 600 for 100k service with cam gears put on (with my parts I already have) water pump fuel filter and all the shit. What you guys recon?
www.revzone.com.au for a second quote.
Did my 200k service. I was down there last week and they had a r35 GTR with the engine pulled out. Engine has to come out when upgrading turbos as the manifold is attached to the turbos
Just to clarify, the bonnet latch handle in he r32s, is It one piece from the front of the bonnet to the cabin? Or can I undo It and buy a new handle.. Need one for road worthy..
bonnet latch is attached to the cable. You would need to replace the whole cable i believe. Someone snapped the plastic handle?
ffs, theres a nut before the cable, tighten the tension?
looks like ill be going to jap heaven this weekend, oh joy
did you replace it??
i dunno why they have to be oem, i had a look at the handle when it snapped and their weak as shit, so i made a stainless steel ring that i would weld onto the pin that the handle sits on. but noooooo has to be oem
Guest
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
    • Ah, to clarify if the car has already been tuned and has been modified and you want to go from a oem cat to a 100 cell or decat or vice versa.Are you saying that the car doesn't need to be tuned after a cat change if it's already been tuned?
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
    • That's the thing, they still add it and it makes fuel cheaper, implying adding 10% of it drops the cost of 91 by what, 5c a liter? I remember when it was barely half the price of 98. Because you know, 85% of what is in the fuel is way cheaper than 91 fuel is by volume.
    • Auto electricians that do repairs on automotive AC systems can source service kits. I don't know where they actually source them. I do know that there is one available for the R34 comp that I would need it for. If you have to pay someone to dismantle, clean and do needed repairs and fit kit contents, then you'd probably end up spending a good fraction of the cost of a new one. I would not be paying for that, because I would be doing it myself. My mechanic (bro-in-law) will happily source what is needed. Back in the day (like in the 80s and 90s), rebuilding an AC compressor was the standard approach, same as for starter motors, alternators, etc, because new replacements were v. expensive. After the China manufacturing boom and the rise of the disposable approach to everything, people just started throwing broken/worn stuff away and not rebuilding things.
