R34 GT-4 + RB26 + turbos + intake + front pipe + flywheel + clutch + wiring loom + ECU + brakes + diffs + exorcist + hub assemblies + brake booster + gearbox + ATESSA controller + dreams + G-sensors + radiator + radiator support + hopes + bumper support + bumper + front guards + rear guards + respray + bonnet + instrument cluster + GTR dash insert + dash mounted gauges + fuel pump + fuel regulator + water pump + oil pump + alternator + starter motor + prayers = 4 door GTR
Fucking just buy a GTR!
:D
:D
yeah exactly. fuck making a 4 door GTR, buy a GTR and tell your two mates to harden the fuck up and sit on the shopping bag tray back seat or catch the bus.
So I saw this in the Stagea Thread...
Guess we will wait for the R33 GTR front...
w..t..f? that's the most retarded looking shit ever. no that GC10 fronted stag was the most retarded shit ever, this is a close second.
looks like someone in thommo had a frontal in a stag and then fixed it using his cousin's skyline parts and shitty fibreglass "widebody" fenders.
:rofl:
what if i wanted to stick a a ford I6 in it..... :down:
GTR-Boy, stop piss farting around, save up your hard earn cash and put it towards a decent car.
lmaoo i already said i want an R33 NA..
and that R32/C34 :) .. wtf
i reckon for your first car just buy any old piece of junk
treat it like ass, dont look after it etc
then when you have appreciation for it and your off the p's
get a nice skyline and off you go
your probably right. but, no.
i love skylines. always have, always will
:rofl:
Not even the Japanese could pull this off this time.
:rofl:
what if i wanted to stick a a ford I6 in it..... :thumbsup:
and that R32/C34 ;) .. wtf
*face palm*
:laugh:
I think he already has a Toyota Hilux to get from A to B.
And for the love of God, love the right one (Skyline).
Guest
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
