I have an R32 gts-t running a slightly modifed rb20. Had an interesting issue today, was driving along when all of a sudden car will not rev and eventually stalls, couldn't get the car started. Checked for air and fuel, no blockages and fuel is coming back out the return so only possible issue is injectors or spark.
I come back to the car 2 hours later and it starts, I drive it the 2 minutes back and after running it another minute or so it cuts out again. At first I think its heat related(ignitor pack) so I leave it for about 4 hours till everything cools down and start it up, after a few minutes it dies again, but starts running again after a few minutes. I took it for a drive and it feels ok until about 3000rpm where it defintely feels sluggish and struggles to build boost. As I turn into my street it dies again. I checked spark and it has none.
2 Questions:
I checked spark by having the spark plug against the head, does anyone know if this is a good enough ground to check it?
Do people think this is a CAS problem, I've got a feeling it is since it was running as if timing was severely retarded.
Any help would be great!
https://www.sau.com.au/forums/topic/310905-cas-problems/
My guess is CAS or TPS.
As far as I know, to test CAS, can mark position of CAS and pull CAS off and I think turn CAS shaft with ignition to 3 (just before turning engine on) and see if injectors click. You'll probaly get a CAS error code on ECU and need to clear CAS error code on ECU by pulling the battery terminals off, pressing brakes to remove any left over charge.
First symptoms of a Faulty CAS = CAS error code on stock ECU and engine is harder to start. I gather when CAS gets worse, stalling, etc. But never had a faulty CAS on engine for that long to find out. If no CAS error code on ECU, oscillioscope is a good tool to use to check CAS.
TPS is another sensor that can cause engine to stall out of the blue. Wiggling TPS plug can somtimes make engine stall or if TPS is misadjusted (not touching idle contact), can cause rpm needle to drop below idle and sometimes not recover when load is applied to engine from aircon, light's, etc + backing off throtttle quickly or going up a hill + backing off throtttle quickly. Or TPS is faulty (low voltages).
Edited by SKYPER
https://www.sau.com.au/forums/topic/310905-cas-problems/#findComment-5120397
I'm running a Power FC so I don't get error codes:/ TPS voltages are fine ranging from 0.4 to about 4.7v.
I'll test the CAS tomorrow and see how I go. Can anyone confirm about being able to ground the spark plug on the head? I'm not keen on stuffing around with the CAS and igniter only to find it is the injector wiring that is stuffed. For further information I'm running GTR injectors with a resistor pack, I did the wiring myself so it is a possibility that over time my shoddy workmanship has come apart:p
https://www.sau.com.au/forums/topic/310905-cas-problems/#findComment-5120425
Dont rule out fuel just because its coming out of the return line, the fuel pressure reg is before the return line, if the reg is not holding pressure in the rail then all the fuel will just be going straight back into the tank with very little if any making it through the injectors.
https://www.sau.com.au/forums/topic/310905-cas-problems/#findComment-5120491
Grounding it on the head is fine, if your not so sure or are having trouble with it, use one of your jumper leads [assuming you have one].
I put one end on an earth point and the other holds the spark plug. That way you can hold the plug up in a better position and don't have to touch it on the motor at all.
https://www.sau.com.au/forums/topic/310905-cas-problems/#findComment-5120504
When it happens next time take the fuse out for the fuel pump turn the ignition a few times then replace the fuse
If it starts first time its flooded and the O2 sensors knackered or an injectors stuck wide open
If its not then I would say AFM on its way out other then that i would need the car and beer to work out what it is lol
https://www.sau.com.au/forums/topic/310905-cas-problems/#findComment-5120660
Yep its defintely not AFM as I still get an AFM reading and I've been able to run the car with a dead AFM just by holding revs, at the moment holding open the throttle does absolutely nothing.
Also there is defintely no spark when the car is dead so I am 99% sure the CAS or the igniter is the issue now. I'm thinking CAS since timing is clearly way out when it is running.
Edited by Kwyjibo
https://www.sau.com.au/forums/topic/310905-cas-problems/#findComment-5120697
When the car is running, have you unplugged the AFM to see if it runs the same or changes ?
You can still get a reading from a faulty AFM.
Tested that today and it runs when AFM is unplugged if I give it a bit of throttle, then once the car died again I tried the same thing and it wouldn't fire up at all. AFM also shows a 0.5-1v reading if hold open the throttle and crank when the car is dead.
Start with the non factory shit... IE YOUR WIRING!
I'm trying a different CAS and ignitor tomorrow but if that fails then I'm checking my injector wiring which is the only other wiring I've modified.
Edited by Kwyjibo
https://www.sau.com.au/forums/topic/310905-cas-problems/#findComment-5121377
    • Had a go at the stuck crush tube this afternoon. Tried things like grips and a chain wrench first but wouldn't just twist straight off. So got to work with a drill. Started small and kept a depth stop on to make sure I didn't drill into the bolt. Made a line of drill holes all the way up and enlarged them. Then a combination of chisel and Dremel to split it all the way up. Levered the split to get oil in there and eventually it gave a bit while levering. Worked it back and forth with loads more oil till it was spinning freely, then with grips I could work it downwards and off. And no significant damage to the bolt (not by me anyway - just the 27 years of rust)
    • Well, I'm tired. I'm tired because about 4PM yesterday, before today's appointment someone immediately bought my bumper. They couldn't get it any other day as they're on the way back to NSW. So I had to do that big GTR conversion I had been planning. Unfortunately, the information on SAU about what you need and how this is done is incomplete. So what should be a simple bolt on affair, yeah, it's not. Did you know if you use all GTR items the bonnet won't close? This little manuever sent me into about 1am the night before trying to dodge a way to get it closed. I will have to revisit this in the next few days  - or maybe not, I may let a body shop figure it out. It all needs to come up and my motivation to pull the bumper off is low. It also seems to hit things in the bay where the GTT bonnet didn't. Yes I used 100% new OEM GTR items. Today, I had the joy of driving to the dyno looking like this: Given I had roughed in the fuel and given sensible but pretty conservative timing, I didn't really bet on having the car drive out any real difference than when it drove in. Sadly due to a miscommunication and laptop fun and games (and almost bricking the dongle, prayers and firmware updates indeed), I ended up using HP Tuner credits to licence the car that was already licenced. So in the end my laptop was used. It turns out my butt dyno is still well calibrated after all this time. The 325kw was on 74% Ethanol, the 313kw line was on 98. The other line is the 'before' line which was 281kw. While the numbers are pretty low, they're pretty in line with what you'd expect. Even if US dynos bump the whole result up about 50KW, gaining 10-15% is similar gains.  The curve of the cam is pretty much spot on with what was discussed as well. All this said, it still feels bad to not see the number you secretly want to see. Even if the car drove great beforehand, and I knew pretty confidently the car would drive out much the same way it drove in due to the nature of a wellish dialled in LS1 not gaining much if anything at all from being tuned from where it was. As expected, the car isn't particularly sensitive to running it at anywhere between 12.0 and 13.0 - And the initial timing at 20deg and 12.0 made 308KW. So 3 degrees of timing, and leaning it out to 12.7 for 5kw, anything above stopped giving any benefit until E85 (which has an additional 2 deg as before). Car itself behaved entirely fine. I found out that 100C = 1.15V! IAT at about 7pm was 19C. I might mess with the bonnet mounting.. but given the REO NEEDS TO BE CHOPPED TO FIT A GTR BAR this is possibly something I may leave gathering (more) dust until it returns to paint jail.
    • It sounds farrrrrrr too cold at your place Duncan... Here I was thinking our 10 degrees overnight is getting cold...
    • oh yeah, reminded this morning....bin lids frozen shut too
    • In my case not, because of total reno. But yeah.
