Hi Guys..
Just wondering what u guys think? I am gettin a 2530 Hi Flow spec Turbo soon but the one i'm gettin is
in a .86 T28 turbine housing in a .60 comp so identical to 2530 except its .64 turbine as .64 will seem too
small for RB25DET.
Will i get slightly more power @ .86? I'm thinking of running 17-18psi so get about 230rwkw and max out the
injectors and AFM when i get my Power FC tune.
I have all the basic supporting mods like FMIC, 3" Turbo Back, Bosch910 pump, Splitfires, HKS EVC, Apexi Pod
with Metal Intake Pipe. Just want to know if i should get anything else like bigger AFM, injecorts or possibly step 1
cams b4 i go 4 the Tune?
Cheers
Ces
https://www.sau.com.au/forums/topic/310925-86-64/
smaller would be responsive but loose top end but if you got bigger it wont be restricted top end and will squeeze more power and will be a tad laggier than the smaller
and would suggest getting injectors and afm but meaning you will have to get a computer of somesort aswell
https://www.sau.com.au/forums/topic/310925-86-64/#findComment-5120652
as above afm maxed out
0.86 housing on a 2530 is defeating the point isnt it ? wouldnt u just be shifting the curve to be laggier effectively ?
that turbo can still only flow so much but is used for reponse on a rb25 with normal 0.63 housing HKS put on it...0.86 housing get more top end but still only flow 230rwkw
https://www.sau.com.au/forums/topic/310925-86-64/#findComment-5122517
People put 2871 .86 on SRs and thats only a 2L (admitantly laggy IMO)
I think the .86 would suit the extra 25% capacity perfectly
As others have said 230kw/308hp would be at the limit of the AFM and injectors
Wouldnt bother with headwork @ that power level
https://www.sau.com.au/forums/topic/310925-86-64/#findComment-5127489
I have a mate running a 3076 (or 3072) with .64 rear housing. He makes 360rwhp, with almost no Lag on a Cam'd RB25 but flat top end.
If he then swaps rear housing for a .82 it can make an extra 50 hp.
The 0.86 rear housing a stock 25 would be good, a bit of lag for a meaty top end.
I would never run AFM or injectors at max. Get a Z32 AFM if you already have a Power FC
Edited by reNEGaDe88
https://www.sau.com.au/forums/topic/310925-86-64/#findComment-5127834
Thanks 4 the Input Guys..
I'm picking up some Pinkish 550CC injectors today and shortly Z32AFM i'm buying over east..
How much a bit more power will i put out with .86 housing as i hear it should hold all the way to
redline and not taper off, make a little bit more power than 230rwkw.. to like 235-240rwkw??
Basically i have a Disco Potato i think.. GT2860RS on .84 Housing on 58Trim.
My Friend adviced me once Injectors are in & AFM that i should get it Tuned straight away n
can't really drive it around much. So i'm thinking i'll get the workshop to install the Injectors and get it tuned
by them straight after.. AllStar Garage perhaps???
Edited by Black_CSR
https://www.sau.com.au/forums/topic/310925-86-64/#findComment-5129559
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
    • I have a 2 lt in Sydney. It was fitted on a R33 GTR, not used for several years . If you are interested email me on: [email protected] I'm not on this forum much .
