Hey guys,
I have recently got my r34 sedan which had a 20DE, running with a RB25DET Neo out of a stagea, Everything is running mint except the fuel gauge, I have exactally 3/4 Tank and as I am driving it drops right down to "E" with fuel light on then it sometimes rises to somewhere on the scale then back to 3/4 again. and basically it appears to have a mind of its own. and yet if I turn the engine off and wait a minute before restarting it it returns to 3/4, Any ideas? I havnt changed the fuel pump for the turbo motor that I have put in, can anyone tell me if the 34 RB20DE fuel pump is different to the 34 GTT and Stagea 25DET? and also if that had anything to do with the above problem,
Cheers
https://www.sau.com.au/forums/topic/310936-rb25det-neo-fuel-pump/
mine's been doing the same thing only over the last 2 weeks though, and mines an rb25det standard from factory R34 GT-t (no engine conversion)
and i haven't changed or messed with the fuel pump either, and its gettin fair annoying not knowing how much fuel i got.. its intermittent though, like the last 3 days it's been fine, but i still dont fully trust it..
i don't know what it would be though :thumbsup:
My main concern is actually the part numbers of the fuel pump that is in the 20de and the pump that is suppose to be in the 25det does anyone know where I can find the numbers of both so I can tell if they are the same unit,
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
