iam replacing the rb20det in my cefiro with a rb30et can i use the existing wiring loom or do i have to use the rb30 loom what is the easiest way
thanks
Ben
easier to use the RB30 loom as the 30 uses a single coil and distributor style arrangement and the 20 is a multi coil-on-plug setup.
better off fitting an RB25 twin cam than the single cam 30 anyway.
you could try and just do a straight engine swap and use all your rb20 loom and gear straight onto the rb30.
its been done
http://www.calaisturbo.com.au/showthread.php?t=149229
i think these are the guys who done it, they made an adapter to mount the cam sensor to the single cam head and delete the dizzy.
http://www.efiperformance.com.au/
  • 1 month later...
  • 1 month later...
 Share
