personally, i think the turbo is a bit too big for rb20, and for such power, power FC will be my choice
Thats fine if you can get a Power FC for RB20s. SAS quoted me around $800 + dyno time which worked out to around $1100-1400 total, so check with them re that figure.
Do you have the specs on the HKS TO4E, Ive only seen HKS TO4S & TO4R. If you are planning on modifying the existing/std exhaust manifold to run the external gate, then you may find the cost and overall performance can be matched by something like a (everyones favourite :P ) 2nd hand HKS 2530.
The HKS TO4 range of turbos are big and not exactly intended for internally std 2.0L engines, especially one with a not so ideal exhaust manifold. (assuming you dont have an aftermarket one)
What power are you aiming for? The HKS TO4S is still rated at 550hp. Also dont go paying extra for the 700cc injectors if you can get 550cc cheaper (from an RX-7)
t04e is the most popular turbo + manifold combo for older RX7's and RB20DET's in japan. They're dirt cheap too, like about 1k for the turbo, maifold, wastegate etc. dun expect stainless steel tho... bit too old.
So those that i have seen with the cast manifold that mount the wastegate up high near the strut is a TO4E??? What are they rated at?
the HKS kit was a lowmount from memory. It was good for around 190-230rwkw depending on what else you modified.
I'm tossin up between this setup and a TD06 atm.
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
    • Ha ha ha, so they stopped the bearings spinning on the one you want, but then decided the crank hub should slip instead 😛   Stick to RB, at least you can work on it yourself. And now it doesn't smell of vapour   Also I still believe there's a chance your new flap doesn't "pop", as even though the engine might breath hard, it has a direct path with no restriction to the inlet, which when on boost should pull a bit of suction for you. If you do get pressure in the catch can id be very intrigued. Time to put a boost gauge on it, and a session at the track, then solid cover your vent and do another session
