Hi Guys,
Surplus to my needs I have a replacement LCD screen for R34 GTR MFD. Working in early model GTR's (1999, 2000, etc), with a 30pin ribbon cable connecting the MFD control boards to the LCD. Can be identified by looking at the rear of the LCD unit, and if it has 1 ribbon cable and is made by Sharp (not 2 ribbon cables and made by Toshiba). This is perfect to fix the lines that often appear through the screen due to our warmer weather.
You must use your LCD controller board, mounted on the LCD unit itself. This is not recommended for people with a dead screen, but is suitable for people with lines through the screen or dead LCD backlight.
Tested 100% working (ignore the fingerprints in the testing photo). Pickup from Mill Park, VIC or $9.00 express postage around AUS.
$230ono
https://www.sau.com.au/forums/topic/310974-fs-r34-gtr-replacement-lcd-screen/
Just wanted to know if you could possibly help me -
I had a fault with my MFD screen that it was cracking/peeling from heat.
Purchased a replacement Sharp LCD screen from Jap Yahoo and upon replacing the original LCD screen I found that the new screen would power up but nothing was displaying on the screen itself - no GTR logo, no data, nothing.
Tried removing and reseating about 3 times ensuring all ribbon cables and connections were secured - all with no luck.
Finally decided to put the old one back in and the old one worked perfectly.
Are there any adjustments or configurations involved if you are only replacing the LCD screen? (and not any of the circuit boards, etc)
The seller of the item stated that perhaps a ribbon cable may be damaged or that the device may have been damaged by static/impact in transit (looked in perfect condition and was well wrapped when received) - and he won't refund or swap for another unit as he tests all units before shipping.
Hi buddy,
My screen is starting to get some cracking, it is a 1999 v spec
Would you be able to give me a hand replacing the screen if I buy it? I have no idea when it comes to things like this.
Thanks
Dave
PM'd mate.
