  • Replies 83
So my 6 massive boxes arrived today! was like Christmas when i got home from work!!!! took some photos will put them up soon the list includes...
genuine front bar, carbon fiber larger lower lip, headlights with eyelids, some crazy looking bosch zenons, radiator support attached to nose cut, genuine bonnet, genuine masa guards, custom bonnet hinges, rear flares and a few other bits.
Hopefully get stuck into it this weekend :thumbsup:
Cant wait to see this one in black? The rear end will need a decent wing, rear bar and chunky sideskirts to make it look right.
Bastid. My abflug kit and eyelids is three weeks from landing. I will be just as enthused me thinks.
Edited by dirtyRS4
nice work, tho i do like the stock rear wing :thumbsup: thinking about rear bars and skirts tho, i wouldnt mind finding a vspec rear bar and drastically modding it to fit the stag :D
ok some pics from today...
Note the welding on the bonnet hinges, looks like a lot of effort was put into getting this car done right.
Oh yeah, seen a few now with GTR variant front bars, good luck fitting a Vspec II rear bar. I reckon a z-tune bonnet, autech wing and nismo or masa skirts would really set it off. Ditch the roof racks aswell.
Edited by dirtyRS4
where did u get the splash guards from and how much, if you dont mind me asking???
they came off the stagea that had this conversion previously, they came with everything else. To me they just look like stagea gaurds that have had bits attached to them
Looks good. Nice to see all the genuine r34 parts have been used. The front bar reo is worth over a grand all up
The peice of foam accross the middle alone is $150!!
I see the carbon lip has a bit of battle damage. They hang fairly low. Mine sits at approx 70-80mm clearance from the ground. A bit too low.
When do "plan" to have it all together?
I was quite chuffed to see it had a genuine reo :( the lip I will have repaired and painted black, it's a bit bigger than the stock lip.
I "plan" to start this weekend, but before I go to far I will be getting the panels edged and and backs painted so the whole car can be blended in the booth avoiding putting it on and taking it off too many times
I was quite chuffed to see it had a genuine reo :O the lip I will have repaired and painted black, it's a bit bigger than the stock lip.
Pic's of rad support? If it has the full R34 support, there will be a bit of time cutting modifing to get it to fit
That lip is actually a one peice version of the factory lip and vspec lower diffuser.
Good idea is to get some 50x3mm alloy flat bar and fix it to the under side and profile it to match the front curve. That way when going thru drivways etc it will scrape the alloy and not wear away the carbon lip. :(
I will get some more pics this afternoon when I get home, the rad support is still attached to the old cars skirts and rails buy after a quick look last night it looms pretty straight forward :(
good idea about the metal under the lip too! :O
Teren, I do plan to come and meet you to compare the AWD chassis to your RWD one soon, but I'm a bit under the weather at the moment and trying to get better.
Hey mate, all good get better first! I'm planning on starting to strip the front of the car on saturday (hopefully) always welcome to come over and check it out :blush:
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
