hahahaha, well waiting on a few things...
new 8000k HID kit coming
alloy intake pipe coming
apexi pod coming
led parkers coming
front mount getting thursday hopefully
new hoses for the bov return and the oil/air from the cam cover
picked up new coolant, side indicator globes and motul auto trans fluid today. getting stuck into the making of the new mounts tomorrow for the thermo, trans cooler mount and bonnet latch brace.
Also the stagea side indicator plugs are different to the r34 plugs, wired them in today. Spoke to the paint shop, they are ready for it once i get it driving...
Hopefully have this thing back on the road ready for paint by mid next weekish... fingers crossed
  • Replies 83
Looking great so far, Teren! Hopefully I'll be able to head around this week (or maybe over the weekend) some time and check it out in the flesh.
I'm back to health, so my aim is to NOT get sick again while out in the wet weather - hopefully it doesn't rain beyond Thursday.
Good to hear mate! bring some membership stuff with you too..... :P
Ok so a little update for those who tune in....
After returning from a quick trip to Singapore... I picked up a new HYBRID GT2 intercooler kit on tuesday, had to make some custom mounts to mount up to the the front reo and mess around with the trans cooler to get it to fit up all nice, also made brackets to bolt up the gtr bonnet latch brace and the thermo fan and modified the trans cooler bracket to fit up to the gtr rad support.
Received my alloy intake pipe and apexi pod filter, and have it roughly fitted up although the filter hits on the washer bottle so might have to see if the S1 washer bottle makes it any better (do S1's have the washer bottle mounted under the skirt where the stock intercooler goes? or do i have some different one?). If that doesnt work I will have to get a hold of a HKS mushroom possibly.
Could have had this thing finished and painted by now if i didnt keep on buying things to put on it! :thumbsup:
Thanks Hugh,
Its an Odyssey fairly certain its this one...
ER40 Specs:
1100 cranking amps for 5 seconds
Short circuit current over 2450A
45 amp hours
87 minute reserve capacity with 25amp load
M6 stud terminal
Length 9.8""
Width 3.8"
Height 8.1"
Weighs 27.5 lbs
Ill check my actual type tomorrow, but im fairly certain those are the same specs
Sorry about the poor quality, these were taken from my phone... Updates so far, front mount in, headlights and other wiring done and working, greedy catch can with braided lines and speed flow fitting's in and apexi pen timer... just took the car for a little punt around the block. Sounds good with the pod / alloy intake pipe :(
Getting the guards, bonnet and lower lip back on Thursday :(
  • 1 month later...
Do you get much reversion messing with the AFM with the alloy intake pipe?
there doesn't seemto be any problems with it but I do have a 45deg silicon bend before the AFM, there was a few problems with revs dropping heaps fast almost causing the engine to stall after fast acceleration then hard braking in full auto, but don't think it was reversion. Possibly the dual port BOV Ihave on it ATM...
looking forward to an update on this one mate!
I will update the latest pics tonight when I get a chance, im waiting to see what wheels you can come up with! :bunny:
I will update the latest pics tonight when I get a chance, im waiting to see what wheels you can come up with! :D
email sent :bunny:
  • 4 weeks later...
Ok, Sorry it has been a while! but I'm just waiting to get it to paint :down:
I have been looking at wheels feverishly, so far these Gram light 57f's look to be winning... 19 x 9.5” +19 front and 19 x 10.5” +29 rears
I have also put the front side skirt pods back on the car along with a JJR Bellmouth stanless front/dump pipe and a HDI Dual stage EBC car is now running 12psi
and for refrence....
My deadline for the paint and to have wheels on it is by the NSW stagea meet in the next few months!
I have also had a chat to a welding friend about removing the roof racks and having the holes welded up, looks promising but will let you know how I go
A few more pics :D
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
