hey guys
ive bought some manifold gasket sheet the one with the metal stuff inside, and was wondering whats the best thing to cut it with ive used sissors to sut the shape out that was fine and a drill to put the stud hole but its the centre bit thats the hard bit ive tried a hole saw, stanley knife and sissors? whats the best thing to use? i know 80% of you will say buy genuine but im not buying 6 x gaskets @45 each? anyone know if a exhuast shop makes up gaskets, im on the gold coast
oh and i forgot to add they are for td05s triangle ones i need 2 x turbo-manifold 2 x turbo-dump and 2 x dump-front
cheers
Ive used many ways but none work well. Snips, holesaws, drillbits, they all rip and tear the metal in the gasket but if you cut undersize you can usually clean it up with small snips.
Clamping it between two bits of wood or alloy, clamp to the table, then holesaw it. Works ok if your drill press is sturdy. Best way would be a proper punch set, one off purchace then you never need to buy gaskets again.
If you had a lathe you could make the punch yourself, do you know someone?
If you have a drill press, use a "gasket cutter" I assume the hole your refering to is the center.
Gasket cutter: http://www.google.com/products/catalog?hl=...IwBA#ps-sellers
Or you can make your own with a centerpunch, piece of wood and a scaple.
Or you could peen it out... ever wondered what the rounded end on a ball peen hammer was for???
Or make a jig and route it out
Or cut a hole in a piece of wood with your hole saw, then use that hole as a guide to cut it out with somthing sharp
J.
    • Good to see your rotors appear as rusty as mine šŸ¤Ŗ
    • Took it for a drive to do some logs, Iā€™m pretty sure my voltage issues and electrical noise issues are gone, Iā€™ve sent a log to Adam and am waiting to hear back with confirmationĀ  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4 Ā  idle video from that day just becauseĀ
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!) Ā  Ā  I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding). Ā  I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springsĀ  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
Ɨ
Ɨ
