NPC make some of the best clutches around. Their twins are used in 1000+hp cars. I run an NPC single with 600hp no problems !
only a single.... launchs, drivability ?? do you know if they are like the Jim Berry ones which have mega clamp like the one I have now with 4200lbs clamp, feels like a sledgehammer hitting the drivetrain ?
https://www.sau.com.au/forums/topic/311033-npc-clutches/#findComment-5121815
Having used both Jim Berry single plate and NPC id have to say that both are excellent in high horsepower applications. My current NPC twin plate cops over 1000hp every launch and is nice and quiet unlike the Jap items that have that annoying rattle.
https://www.sau.com.au/forums/topic/311033-npc-clutches/#findComment-5121833
thanks guys, sounds like NPC know what they are doing... will call Doug back and get me one....
still trying to get head around 9 seconds-------------- respect
the 9.4 was a piece of cake...car was not properly sorted...this time next week will see some real numbers :)
https://www.sau.com.au/forums/topic/311033-npc-clutches/#findComment-5122221
  • 5 weeks later...
Has anyone had any good or bad experiences with the NPC range of twin plates..........
or what about nismo coppermix twins are they rebuildable ???
I had one in my rb30/26 running 580hp and the preasure plate smashed after a week and destroyed my gear box. I was only running the cluch in no launches at all. It was a single plate 5puk from npc
https://www.sau.com.au/forums/topic/311033-npc-clutches/#findComment-5167836
ive used alot of clutch brands and my npc twin is by far the best drivability and ive never had any hint of slip with 600rwhp, 1750kg car and revlimiter drag launches with a dogbox. I have used an os giken quad and it was annoying to drive, on and off engagement which sucks. The NPC is so smooth to engage and its such a soft pedal feel considering the power it can hold. I would have no issue using it as a daily driver clutch its great.
Ive also used direct clutch twin plate, extreme singles as well to compare.
They are cheap too compared to the jap brand options so its definately got no compromises.
https://www.sau.com.au/forums/topic/311033-npc-clutches/#findComment-5167938
  • 1 year later...
From the last time it shit its self I sent it back and had it rebuilt to handle even more power. Funny thing is I'm running less power then last time. Now 450hp and the piece of shit clutch let go yet once again but this time it smashed the box clean off the block. I was changing from 2nd to 3rd. I should of learnt work's the first time it let go. Now I will use what I know works. Hks or os or a orc so I don't have to pay labour to remove the gear box and pay for a new box and clutch because some price of shit clutch can't handle half of what it is built for. Buyers be warned. And customer service is f**ked when you send them back. They try anything to get out of it
https://www.sau.com.au/forums/topic/311033-npc-clutches/#findComment-6155365
was this the NPC 10inch ceramic button sprung clutch? I'm having one installed in my GTR today (380awkw) - I hope to God that I don't have the issues that happened to you. I guess I'll find out soon enough lol
https://www.sau.com.au/forums/topic/311033-npc-clutches/#findComment-6160728
I have that clutch, no problems at all
Not as much power as you but
Can I ask why you didnt go for a twin plate NPC?
  • Like 1
https://www.sau.com.au/forums/topic/311033-npc-clutches/#findComment-6160762
basically I just wanted a quick swap over clutch so I didnt have to leave my car at a shop for a week or two while my OS Giken twin plate gets rebuilt. I was told this clutch can handle 600hp at the wheels - so I thought I would try it (cost were much cheaper than the NPC twin). At worst I can always get the OS Giken reinstalled (after rebuilt) if I'm not happy with the NPC 10" ceramic button sprung clutch.
I'll do a review on the NPC 10" ceramic button sprung clutch after I run it in - will post it on this website. Hopefully my pressure plate won't explode.
https://www.sau.com.au/forums/topic/311033-npc-clutches/#findComment-6160827
Ah fair enough
Not sure if theres any difference between the GTR and GTST clutches, but mine has a lighter pedal feel than my old exedy cushion button, isnt to much worse to live with every day (takes a little while to get used to but not so bad)
Bites damn hard, and has never slipped for me once. Going strong for over a year now.
I dunno what else to say about it lol
https://www.sau.com.au/forums/topic/311033-npc-clutches/#findComment-6160922
that sounds positive - hopefully my new clutch performs like yours
Ah fair enough
https://www.sau.com.au/forums/topic/311033-npc-clutches/#findComment-6160975
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
