Have been wondering why i was getting very average fuel consumption on my GTT. I knew i was never gonna get fantastic figures but more than what i have was to be expected since it is completely stock and have been driving rather sedately.
Anyway last night i filled up with a little fuel and saw some moisture inside the fuel cap area on the metal lip. Smelt it and was definitely fuel so now i know where at least some of my fuel is disappearing but i have no idea what could cause this issue? Is it a case of getting a new cap?
https://www.sau.com.au/forums/topic/311064-fuel-leaking-out-fuel-filler-cap/
i'm assuming that you saw this before you took the cap off, etc? if you had been leaking fuel out of there then there should've been some sign of it down the side of the car.
if you are worried about it though, just get a new fuel cap.
and what sort of economy are you calling average? and please don't simply say "i got 300kms to a tank" because "a tank" isn't a unit of measure unless you fill it to the top then drive it till it runs out of fuel. how many kms are you doing for how many litres you put in? also what do you class as sedately? flooring it but only reving it to 3500rpm will still use a fair bit of fuel. how far you push the accelerator down plays a bigger part in fuel economy than what revs you change at. and if you regularly go into positive boost (even at low rpm) then that will increase fuel usage as well.
i was getting about 17L/100kms but i was a bit of a leadfoot and i did a lot of short trips and it was pure city driving, so nothing above 60km/h and never for more than about 1km without having to slow down/stop at an intersection.
other things that can contribute to poor fuel economy is a dodgy o2 sensor or dodgy thermostat. you can tell if the thermostat is dodgy by how long the car takes to come up to operating temp. it should take about 5 mins of driving. if you sit the car and let it idle for ages in the morning before driving it will take longer than 5 mins and also waste a heap of fuel. you can test the o2 sensor with a multimeter
My economy definitely isn't as bad as 17l/100km the full tank in the r34's are 65l i think so i would of used 55l for 380kms so 14.5l/100km.
I don't bother idleing the car to get up to operating temperature as i know it's a waste of time and car does get to operating temperature in around 5 mins.
Generally i try to drive off boost altogether and try not too have it planted at low revs as feel this is putting too much strain on the motor.
I do have a fair few short trips although did a fair bit of highway k's this time round thats why i was unimpressed with the figure. I will keep an eye on it try and see if anymore fuel leaks out might try not goin a full tank and see if it still leaks
on the highway, driving mostly sensibly i only got around 10 or 11L/100kms. doing short trips will make your fuel economy worse as the car runs more rich when it's cold, and driving short trips doesn't allow the car to get up to temp and into the leaner running, so you can drive like a granny and still not get as good economy as someone who drives twice as far.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
