Just curious where everyone has the amps mounted in their R34's?
I thinking of putting them in the boot above the petrol tank but interested in other opinions
you can put them there,but make sure you can still get to the wires etc on the fuel pump if it dies and dont drill into the floor = fueltank , or behind the side panels there is heaps of room, but you better know how to mount them without denting or piercing the outside metal skin. and then you can hide them completely
or false floor above spare tyre. don't recommend ditching the spare for audio gear unless its a show car only
side panels in rear seat area has a bunch of room behind the "flux capacitor" panels(the one with all the bolts holding them on..lol) but stear clear of seat belt pre-tensioners on the reels. (yellow wires)
under front seats, not a real good spot on that car
depends on size,heat, your goal, to hide them or show them off, expense to do right, skills if you do it yourself ? lots of factors
My mate and I made up a false backing from MDF then carpeted it, and drilled out holes for the wiring where the step at the back of the boot is to mount the amp to. Was alot of work but it worked out well as it looks neat, is out of the way and hides most of the wiring
This is it:
see the bolt in the upper left corner, it screws into the metal bracket behind the carpet cover
and scotty doo I hope that fuse isn't the one for the battery . you do have one up front very near the battery don't you ??? if not your asking for a massive car fire(unless your battery is in the back of the car now ?) you don't have to give up so much space. the amp can get a lot closer to the seat back , but don't put the power wires too near the computers in the back if you can help it.
You're right we bolted the MDF board at the top on either side, and the bottom of the board sits behind the lip on the step. The two bolts hold it in very securely, and is easy to take out.
Yes the fuse is the one for the battery and the battery is in the engine bay still. Thanks for pointing this out, we were going to put it in the engine bay orignially but decided to put it in the boot for aesthetic reasons, but didnt think about it enough obviously. We'll be putting one in the engine bay now too very soon. :P
On the use of space, I've found where it is to be pretty good actually. I never used the shelf part of the boot anyway and the amp doesnt stick out very much at all beyond that point. I could have mounted the amp on the inside of the board but I wanted to show it off a little. And the Sub is really quick and easy to grab out too if I need the space. Putting the board back any further would have just made things so much more difficult and time consuming it just didnt make sense for a nothing space. The gap behind it is good for hiding the extra length of wiring too. And none of it is anywhere near the computer gear for the car either.
Cheers.
On mine I only have 1 bracket in the middle that holds the carpet and it seems pretty flimsey
there is a pretty thick steel plate , between the front and rear part of the car. on coupes to stiffen the chassis , weighs a bunch but does help a lot for rear stiffness. pull out your rear seat you can see it and access the bolts to it. also there is a lot of bolt down holes along the rail near it. 10mm bolts
if you want to hang a bracket off it. or you can look up under the rear deck, a few spots to hang a metal bracket down to secure a amp rack.or epoxy a bracket on the floor if you don't want to drill for fear of fuel tanks, brake lines, etc. ? I would hang a amp inside the rear panels to hide it and still have cooling, and you can mount a up to 12" sub on either side , behind the panels as well. without major drama or hacking
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
