I have one serious question, please excuse my ignorance and give me a constructive answer if one is needed :) Why do most of us want/need an aftermarket boost gauge? The factory item goes up to 1.5 bar, and I and probably most others don't plan to run much more than 1 bar without some serious engine mods, so why do so many people want aftermarket gauges?
I had one on my car when I got it, but it was half-blocking the tacho and I found myself bouncing off the redline way too often because I couldn't see it! So I took it out, plugged up the extra vacuum line hole and have been using the dash one and the digital readout on the boost controller ever since. They both match up almost perfectly too. At 0.8 bar on the Greddy box, reading about halfway to 7 on the dash gauge.
JimX.
https://www.sau.com.au/forums/topic/3111-what-boost-guage/#findComment-53470
JimX.
I always thought the boost gauge built in standard on my dash just went to 7psi?
I have a Greddy Recall boost gauge. I have different options of how i wanna view my gauge. I can view boost in real time eg exactly what boost i am pumping out right now or i flick it to memory and it shows me the highest amount of boost i have used throughout my travel. Good for measuring how much boost i have coming through after winding up or down. It cam with the car but if you can get a Greddy recall boost gauge go for it it is pretty cool!
https://www.sau.com.au/forums/topic/3111-what-boost-guage/#findComment-53520
The factory boost gauge is way too slow to react to quick changes and spikes. I certainally would use it to set your bleed valve.
Plus the factory boost gauge isn't in psi. I think 7 on he factory gauge is somewhere around the 14psi mark.
If you want a after market boost gauge that looks factory, have a look at the VDO range. The 52mm ones have -20 Vac through to 25psi, are black faced, black bezel, white numbers and red needle.
I think they are around the $150 mark each.
I have a twin A pillar gauge holder in mine with a oil temp and boost gauge from VDO, and I'm always asked it is factory cause it blends in well with the dash.
But I've been thinking about moving them down to under the stereo....... Hmmmmm, not sure yet......
J
https://www.sau.com.au/forums/topic/3111-what-boost-guage/#findComment-53569
Yeah as Jay95R33 said the factory gauge isn't in psi, it's in 100x mm of Mercury, and 7 of those I thought was around 1.5 bar but after double-checking the formula it's actually around 1 bar (13.535746 psi to be almost precise). So at max boost I must be getting a bit over halfway on my gauge. Anyway even at 1 bar it's good enough for me for the time being.
Jay95R33, I agree it's pretty slow to change, but I've also got my digital readout on the Greddy boost controller which is pretty much instantaneous.
I dunno, I think I will take the one I removed from my steering column and mount it on the A-pillar one day, but for the time being I don't see it as an essential item. I definitely wouldn't use the factory gauge to set anything up to precision, but I think for general driving it's good enough. As long as you're running 1 bar or less :)
https://www.sau.com.au/forums/topic/3111-what-boost-guage/#findComment-53594
Some of you guys pay mega bucks for guages! Far out.....
I just bought a Speco boost guage. Its white faced, has a silver rim, goes to 30 psi, and 30 IN-Hg vac. It cost me $62.
Also bought the Speco chrome cup to go with it, this was $40.
Not bad I thought, considering i paid about $150 for the autometre boost guage I had in my old ET pulsar, with out the cup.... :D
Steve
https://www.sau.com.au/forums/topic/3111-what-boost-guage/#findComment-53661
| hype^ |, no. But I have an electronic boost controller with a digital readout, and a dial to set it from the dash instead of the engine bay. Sure I would use my Autometer gauge to set the boost if I had to use the bleed valve but I don't think I'd leave it in there permanently. It was certainly in the most ridiculous spot when I got the car on top of the steering column, if I put it back it's going on the A-pillar.
Just over half on the factory gauge is about 0.6-0.7 bar I'm guessing. Exactly halfway *should* be around 0.5 bar (7psi), but it could just be a margin of error in the boost gauge.
https://www.sau.com.au/forums/topic/3111-what-boost-guage/#findComment-53872
MIC, a good way to do it is find an uphill stretch of road where you can load up the engine in 3rd gear. At 5000 rpm thiis is pretty quick so chose your road wisely.
HYPE, if you have the standard boost control (factory) you will get an increase in boost at around 4500 rpm to about .8 bar/11 psi/570 mmHg. Below that you will only get around 7 psi.
https://www.sau.com.au/forums/topic/3111-what-boost-guage/#findComment-54402
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
