hi guys while i have no engine in my car iam goin to replace a few suspension components
what are the longest lower control arms i can bolt onto my setup
i have :
r33 brakes 5 stud conversion
tein cefiro coilovers with camber tops
i will also be using adjustable castor rods
iam looking for more camber what have u guys used
https://www.sau.com.au/forums/topic/311100-cefiro-front-lower-control-arms/
  • 1 month later...
s14 and r33 lca's are the same length but 33 arms give you more lock cause the stops are in a different place prob the best option cause they'll fit straight in and with camber tops i can get like 9 degres negative camberon mine
Excess static camber is going to reduce your braking power and severely increase your tyre wear.
R33 LCA's have different mounts for the swaybar. You could always just remove the lock stops on an S14 LCA, otherwise it'll be drilling holes in the R33 LCA for the swaybar.
R30 LCA's sound interesting
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 馃槢   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 馃槢
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I鈥檓 the new owner of a 1996 R33 GTS-T, I鈥檝e purchased this car over from Queensland and brought it to Western Australia and I鈥檝e found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
