After several years, I finally through my principles out the window and got a personal loan.
A little history:
Out of school, I'd been trying to keep an 1984 Gazelle on the road, first with a CA20 then with a CA18 and various suspension setups, and it simply wasn't viable as a Daily driver. I had crashed it once, foolishly (& expensively) repaired it. I had on-going engine problems since, and I was spending, on average, $200+ and at least one weekend every fortnight trying to keep it in drivable condition just to get to work. I still have it, and 'play with it' when I feel like it, but I'm no longer under pressure to use it daily.
So, after a few nights of sitting down doing calculations, and a few months of researching and searching, R32's (my first love), JZX100's, XR6T's, R34's, and nearly buying an R32 4-door, (which I still like a lot) I found this pic on carsales of a fresh import:
It had nearly every option I wanted from my R34;
Black
Full Factory Kit (actually a Nismo Aero front bar)
GTT (it had to be RWD)
4-door
Sunroof
Series 1 interior (pre 2000)
Premium Pack
- Premium Audio
- TV/Nav
- Auto Headlights
- Rear console drink holders
Dead stock
Only thing it wasn't was a manual, and to be honest, after driving it, I like it how it is. Suits my needs better.
So, in September after about a week and a half, a 1500km roadtrip, a week of BS at regency, I had a driveway like this:
To date:
First things first, I got it booked into a workshop and replaced every fluid in it, machined the discs*, and put a set of new Bendix Heavy Duty pads** on it before they put it on the dyno to check that it was ok on Aussie fuel. (135rwkw btw)
*I could feel that these were again warped after 2 days driving to work, and 0.5 of a hills run. :)
I bought some DBA4000S for the rear, fronts and QFM pads pending finances, before I put them all on.
**In my opinion, Bendix HD pads are terrible. I was recommended them as a good street pad with NO noise, and low dust. They are NEITHER of these. 2.5 weeks in, they were squealing under light braking in traffic, and always when hot.
They are quite dusty. I will never buy bendix pads again if there is a better option available.
Immediately after the workshop, it was booked into Tint-a-Car for some UV protection with a 25(!) year warranty.
Since then, after a month of no audio because the Xanavi unit needed a reboot disc, I bought myself a birthday present: A complete GTR centre console stack, with the A/C controls at the top, factory CD in the middle, and a flip-open pocket at the bottom. Intalled it along with an FM expander, and had audio everywhere except driver's door. :laugh: Later, after an afternoon of investigation revealed that a relay attached to the Xanavi Nav/TV system had the driver's door speaker wires lead to it. If that relay is unbolted from the xanavi unit, put back in the car and the correct factory looms connected, it WILL all work :D
Future plans: Ensuring reliability and daily drivability are always first priority, a few cosmetic subtleties, internal and external. I plan to keep this for fair while, and am in no rush to do anything, especially not before it's paid off.
The concept of the car is to be a reliable and comfortable daily driver, that is neat enough to park next to Merc's and BMW's without attracting death stares when I pick up my girlfriend from work, yet still have better than average performance, not attract negative attention from the authorities, but still be recognised by import enthusiasts for what it is.
https://www.sau.com.au/forums/topic/311123-r34-4-door/
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
