Hi all,
For sale i have a pair of BRIDE style Low Max Carbon Fibre seats. Seats only no rails.
I ordered these a few days ago and no longer need them. They are still in transit and would like them to be sold before they arrive.
Price is $1300+ delivery.
https://www.sau.com.au/forums/topic/311164-bride-style-low-max-seats/
Taiwan or China not sure.
I guarantee if you had the genuine ones and these ones side by side you will not be able to tell the difference. Hence why i bought these specific ones.
But now the car is going into a different direction and i no longer need them.
hey mate. i would be keen on these seats for 1200 delivered to gold coast. as long as they are the good quality copies and not the dodgy ones that just break.. u mentioned that u bought those particular ones for a reason. what is this reason ie; ur mates have the same seats or u have seen them in person and can vouch for the quality.
  • 1 month later...
Im interested in these seats if you can supply them with rails to suit my r33 gtst.
I want to be able to mount the seats straight in with zero modifications
Im in sydney, if you can work something out we can go ahead.
Also can you confirm if these seats are ADR approved or full defect material.
thanks mate
No Bride seat is ADR approved. I have a Bride rail to suit a GTST just not sure if the the bolt holes line up with the seats i have. I will check it out for you.
If it fits add $150 for the Bride rail.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
