I have a series 1.5 and pulled 165rwkw on stock boost with only an exhaust and front mount - sounds like something is seriously wrong with your tune and/or engine. Even conservative dynos shouldn't be showing what you got.
Ive not seen a apexi boost controller before but thats what ive been told the car has, When i bought the car though it was running 1.5bar with the stock turbo, im hoping the power delivery isnt to do with the turbo being stuffed?
Errr...1.5 bar? I wouldn't run 1 bar on the standard turbo. The fact it hasn't blown itself to pieces is nothing short of extraordinary - consider yourself lucky you only have power loss! I suspect it might be damaged though?
i wouldn't jump to that conclusion just yet. generally if the turbo is shagged then it generally won't build boost at all and it will either blow smoke or make horrid noises.
if the car has an electronic boost controller then it may be the gain settings, etc that are causing the slow boost rise. i personally don't like electronic boost controllers for running relatively low boost, but that's just me. if it was me i'd be disconnecting it and getting one of the cheap turbotech boost controllers and running that. also make sure you aren't relying on the stock boost gauge.
another thing to look for is broken manifold studs. pop the bonnet and look at the exhaust manifold to see if there are any studs missing. there should be 2 per cylinder. if he was running that much boost then it wouldn't suprise me if there are a few broken since the cars are getting on a bit now and nearly everyone i know (people i actually know, not just randomly talk to on here) with a 33 have had a broken manifold stud. i did with mine, as did a mate who i put a bigger turbo on for, and as does another mate with a 33.
Im not sure how you go about changing the gain on this boost controller, unless its done by the pfc?.
I have changed the gaskets on the manifold and the turbo and all the studs seem to be intact.
Would the turbo behave this way if it was only slightly damaged ie: small chips on the blades?
Im thinking maybe the tuner has retarded the ignition, i have not looked at the service manual for an r33 yet and have not had a chance to check it myself, also im not sure if he can alter the timing under load in which case im not sure about checking it at all.
Thanks for the response.
Chris
  • 1 month later...
Hey all
just an updateon this thread. have purchaseda set of the yellow jacks coil packs and they have made a massive difference to the car. Havent had the chance to get another tune but the car is much more drivable and much better on fuel (still drinks like a fish) 350klm's to a tank max.
Another question relating to my PFC, i was looking through the settings menu and within the afm menu i discovered an option ive not heard of before. There is a listing for a Super Intake afm just below the Normal R33, have done a search but cannot find any info on this, i am just curious
Regards
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
