L28+5 Speed
Hey guys and girls
I have almost finshed the front end of my c110 and am think i replacing the L24 with a 28 manual.
Anyone seen one for sale cabbie is what im chasing.
Is any/much mods to the loom required as it mite be eazyer to do while its out.
Cheers Brad
You can talk to Carlos Casmiri at Sportsclassic http://www.sportsclassic.com.au
Address: 1077 Castlereagh Road,
Castlereagh NSW 2749
Postal Address: PO Box 1257,
Penrith NSW 2751
Phone: (02) 4776 1174
Mobile: 0418 284 776
Email: [email protected]
Business Hours: STRICTLY BY APPOINTMENT ONLY.
Please call to arrange an appointment.
Dealers Licence: DL13543
Carlos is a bit up and down with his prices, but always worth a try.
Note that L28/L26 Cranks have a harmonics point and are prone to break unless you fit a very expensive harmonic balancer.
We use an L28 Block with L24 crank and rods (effectively the same as boring out an L24 out by 3mm (120 Thou) to 2.6L and is very oversquare, so it rev's like a sewing machine and is pretty bomb-proof :( ...
http://www.ozdat.com/ozdatonline/enginedesign/
Cheers,
Daewoo
Cheers,
Daewoo
Thats very close to me mite go down and see them.
Make sure you call first.
It is as big as any wreckers I have seen, but it is only Carlos and run on the same property as his home...
Plus he is very involved in Rallying, so you never know when he will be home...
Cheers,
Darryl
 Share
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
    • https://www.carsales.com.au/cars/details/2021-nissan-skyline-400r-auto-rv37/SSE-AD-17857548/ Well there you go
    • Chris won't reply. He doesn't visit the forum much anymore. You can try these guys https://www.facebook.com/autotainment/ They did mine many years ago
