Hey,
I was cleaning my AFM today when i noticed there was a plug/socket (grey plug with no wires attached to a small black box) on the top of the engine, just near the intake plenum which looked a bit odd because there was nothing plugged into it.
so i googled a few pictures of rb25det's and they all seem to have something plugged into it.
here is a picture of what mine looks like,
and here is one that I googled looks like,
Also how much should the stock boost gauge read on a manual r33 with a blitz catback.
Any help would be appreciated, thanks.
Cheers,
Scott
Edited by scotty_1989
https://www.sau.com.au/forums/topic/311244-help-r33-gtst-question/
the good news is you do have the plug....its only the wiring to the plug that is missing!
no idea what it is, its plugged into the throttle body but it can't be the throttle position sensor unless your car runs horribly or not at all
its the throttle valve switch connector/sensor (Automatics)
page EN-68 in the R33 workshop manual
normal boost should be about 5ish psi with a catback (somewhere in between -7 and 0 on the factory gauge)
Edited by BstewyR33
cheers heaps guys I just bought the car a few days ago and was stressing a little haha..... When i hit boost the factory guage boosts to about the half way line between 0 and +7 on the gauge, is that correct? Also why do you recomend mod wise first, bigger fmic or full turbo back exhaust?
Cheers again
if you've got the stock air box, get yourself a decent panel filter or go get a decnt pod filter (if you want to go down that path), 3 inch exhaust turbo back (or keep your catback) up to you, then you can start thinking about a front mount
cheers for the advice, i have a pod filter on the way, got an apexi power intake, so ill install it as soon as it arrives......As for the next step, wasnt sure whether to go turbo back exhaust or fmic, you recomend exhaust first though yes?
cheers
cheers
personally i'd go exhaust 1st (with a highflow cat), as the above fella said, thats just my opinion haha, my reasoning is, why upgrade your cooler to a front mount if you havent got the exhaust to capture the extra gasses. (note: there wont be a massive amount more, however every little bit of exhaust scavenging won't hurt)
that would hopefully stop all the popping sound from an exhaust if its just cat back.
then get your cooler. :(
just my advice
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
