1991 Nissan 180sx Rb20
Item Summary: 1991 Nissan 180SX RB20 twin plate clutch, E11v2,GT3071, injectors,manifold,coilovers
Condition: Good
Reason for Selling: Marriage , Kids
Asking Price: 9000 firm
Delivery Methods: PickUp
Contact Info: [email protected] or pm
Extra Information:
Make: Nissan
Model: 180SX
Engine:RB20DET
Forged pistons
Flowed head
ARP Stud Kit
JJR coilpacks
Custom FMIC
3 Inch exhaust
440cc injectors
Custom Exhaust Manifold Extreme turbo manifolds T3 flanged
Garrett GT3071r .84ar
38mm Turbosmart progate mounted on the housing for better boost control
Screamer pipe (can organise getting it plumbed in for the new buyer)
Custom Dump pipe
Braided Oil & Water Lines
Custom Catch can
Modified Plenum to be forward facing
Modified custom radiator
Haltech E11V2
Haltech Boost control
Davies Craig 115l Electric water pump
Gearbox: RB20 5 speed
ATS twin plate carbon clutch
Body Mods: 17inch wheels
front lip
Suspension: D2 adjustable Coilovers
drift pineapples
Interior/stereo: No stereo yet
White faced dials
AutometerBoost Gauge
Autometer oil pressure gauge
Autometer water temp gauge
Splitfire Volts gauge
Haltech shift and warning light
Power/Times:234rwkw @20psi
[email protected] on the slipping clutch
Hey guys time to sell my pride and joy ive finally got the package together and working after 12 months and now its time to sell up and buy a family car so willing to accept a swap for a ford territory and ill add cash or for a cheaper 4wd with cash my way.
the car runs well and has a few minor things that a new buyer should touch up but all in all you will get it all done for under 10k and you've got a pretty sweet ride
  • 5 weeks later...
 Share
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
    • So, to run the 4g aerials to the booster, I had to get access to the rear bulkhead....bit of a mission. Hot tip, don't offer to help change the rear shocks for a mate with a v37.... Remove seat base, 2 clips that slide forward to release it the it lifts straight out Fold down rear seat (pull in from boot) The side bolster of the rear seat is not connected to the middle parts that fold. To remove unbolt at the bottom bolt then push it up off the top hook Then there is a plastic surround behind the seat back, 2 pop out clips, 2 bastard clips, some swearing at it is out Pop the rear seat latch surround off Remove door surround lower trim then side trim  Remove c pillar trim - 4 clips, pull inwards not forwards Remove metal brace - 5 bolts 1 nut Then you have got to the rear strut top...what a pain!
