Car in question is a R33 GTS-T only mods are a front mount, CAI and a larger exhaust from the cat back (so I dont think it would really affect the back pressure)
So my car has been boosting to around 12psi no matter what setting I put the boost controller on... I removed the apexi boost controller and put a new hose with new hose clamps straight from the wastegate actuator to the intake piping. Car should be running 7 or 8 psi now like stock.
Anyways it still overboosts, I can hit 12psi in any gear if I plant it, im sure it would go more but the car starts to miss or backfire and starts acting all jerky.
Does anyone else have any ideas of anything else to check before I replace the wastegate solenoid?
https://www.sau.com.au/forums/topic/311283-wastegate-actuator-problems/
Its an L shape. Comes off the side of the wastegate heading to the side of the car then it bends heading towards the front.
kind of looks like this one http://www.nissanparts.cc/catalog/nissan/R...SM%20NPLOGO.jpg
Edited by ascenion24
I cant for the life of me find a replacement actuator, all the generic ones have a straight pushrod and it wont clear the turbo outlet...
anyone got ideas?
Does the standard actuator pull apart so I can replace just the spring or do I have to replace the whole assembly?
I cant for the life of me find a replacement actuator, all the generic ones have a straight pushrod and it wont clear the turbo intake...
anyone got ideas?
Has always done this since Ive had the car, which has been only a couple of weeks. I thought it was the boost controller not working properly so I removed the boost controller and it still over boosts.
I can move the actuator rod with a pair of pliers, But I dont know the limits of how much it should be able to move, it could be getting jammed and I dont even know.
Actually Ill move it by hand and measure the throw, then ill put compressed air to it and measure the throw. If the throw is less with the air then the actuator is stuffed. If the throw is the same then something is stopping the wastegate from opening completely and will probably need turbo out to inspect.
Am I on the right track here?
hmmm... just ran a test.
Hooked the air comp up to the wastegate and the rod moved the same amount that I can move it by hand. (If I grab the rod with pliers I cant move it I have to grab the connection at the turbo and twist, should it be easier to move?)
So it seems as if the swing valve is getting stuck, but its a stock system so I cant see anything being in the way.
I'm not sure what to do here, the test wasn't exactly scientific so not sure if I can rely on it.
What should I do?
Personally I'd try taking the c-clip off the actuator arm at the end where it kind of bolts onto the gate, then see if you can turn the little flap easily enough by hand, it should just be loose as anything.
Just to rule anything out at that spot.
Will give it a try tonight, how much should the wastegate move from closed position?
I drew a quick diagram to help explain, the diagram shows the lever in the closed position, should it be able to rotate only 45 to the vertical? or upto 90 degrees? etc...
Thanks.
Hey mate, going from memory I think it's more like this, but I could be wrong..... I didn't take much notice last time I had it off
Whether it's 90* or 135* I'm not sure, but it's definately in that area
Edited by mosquitocoils
Sounds silly but have you checked to see if the Restrictor is still in this pipe????
If not get the tappered end of a bic biro and stick it in there that should stop it over boosting
Edited by jjskyline79
Restrictor what?
I've replaced the pipe with a new piece of fuel pipe to make sure there were no leaks.
So without the restrictor it would overboost?
Ill check the old pipe.
Also do you need the restrictor when using an aftermarket boost controller? When I had the apexi hooked up it was still over boosting.
If you want to run the higher boost, try gapping your plugs closer together. The standard coils can't deliver enough spark when there is higher boost so blows out the spark. If you reduce it to 8 mill gap if i remember correctly this should give you enough to run the higher boost.
Not the problem but hey :cool:
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
