Hi guys,
I've got the usual 'stage 1' mods on my r33 gts-t as well as an SAFC 2.
Thinking about hi-flowing the stock turbo, but i'm worried that the SAFC might not be enough.
In its current state, the car makes 170kw, and i'm aiming for the low 200kw area.
Will the SAFC be up to teh task? Or should I ditch it for a remap or PFC? Preferably not a PFC ($ etc)
What are your expert thoughts?
https://www.sau.com.au/forums/topic/311284-safc-and-hi-flow-turbo/
First thing would be to list the mods you currently have.
You should be able to get close to 200rwkw without a hiflowed turbo. That would be where i would start. The safc is definitely fine for that.
http://www.skyline-owners-club.com/forums/...ning-guide.html
IMO, biggest problem with the safc is people not understanding that it also has an effect on ignition timing. as long as you find someone who knows how to tune it you should be fine. that said, with the price of nistune computers these days, i wouldnt waste my money on an safc
My list of mods is basically as follows:
Front mount cooler
Hdi Ebc-R set at 12 psi
3" turbo back exhaust
Apexi SAFC
Exhaust cam gear (not dialed in as yet)
Dynoed at 170kw. Only got a gain of 10kw from the SAFC up from a previous 160kw.
Definitely not the gain I was after, especially given i've heard bigger gains being had on this forum. :(
Honestly - tis a bad plan in my view :)
To make the most you would also need the igniton controller (S-ITC i think its called) installed to complement the S-AFC
By the time you put those two in, you can virtually have aftermarket management purchased... yes there are tuning costs still to go but it's not that bad overall.
This would lead to a car that overall will be signifigantly ahead of the S-AFC/S-ITC dual controller style setup in driveability, economy & overall map/power and functionality. It is also simpler - Once ECU, one plug, one job. Not multi wire cutting and so on.
S-AFC's have thier place, not arguing that.
In my opinion that is only for the factory turbo for someone looking for some gains, cheaply without the expense of aftermarket management.
However as soon as you upgrade turbo - because lets face it, that means AFM and usually injectors as well - then its time you also pony up for some better management rather than signal benders like the S-AFC/ITC and so on.
standard turbos wont make 200rwkw on all cars and all dynos.
best option would be a nistuned z32 ecu
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
