Hi guys,
I've got the usual 'stage 1' mods on my r33 gts-t as well as an SAFC 2.
Thinking about hi-flowing the stock turbo, but i'm worried that the SAFC might not be enough.
In its current state, the car makes 170kw, and i'm aiming for the low 200kw area.
Will the SAFC be up to teh task? Or should I ditch it for a remap or PFC? Preferably not a PFC ($ etc)
What are your expert thoughts?
https://www.sau.com.au/forums/topic/311284-safc-and-hi-flow-turbo/
First thing would be to list the mods you currently have.
You should be able to get close to 200rwkw without a hiflowed turbo. That would be where i would start. The safc is definitely fine for that.
http://www.skyline-owners-club.com/forums/...ning-guide.html
IMO, biggest problem with the safc is people not understanding that it also has an effect on ignition timing. as long as you find someone who knows how to tune it you should be fine. that said, with the price of nistune computers these days, i wouldnt waste my money on an safc
My list of mods is basically as follows:
Front mount cooler
Hdi Ebc-R set at 12 psi
3" turbo back exhaust
Apexi SAFC
Exhaust cam gear (not dialed in as yet)
Dynoed at 170kw. Only got a gain of 10kw from the SAFC up from a previous 160kw.
Definitely not the gain I was after, especially given i've heard bigger gains being had on this forum. :(
Honestly - tis a bad plan in my view :)
To make the most you would also need the igniton controller (S-ITC i think its called) installed to complement the S-AFC
By the time you put those two in, you can virtually have aftermarket management purchased... yes there are tuning costs still to go but it's not that bad overall.
This would lead to a car that overall will be signifigantly ahead of the S-AFC/S-ITC dual controller style setup in driveability, economy & overall map/power and functionality. It is also simpler - Once ECU, one plug, one job. Not multi wire cutting and so on.
S-AFC's have thier place, not arguing that.
In my opinion that is only for the factory turbo for someone looking for some gains, cheaply without the expense of aftermarket management.
However as soon as you upgrade turbo - because lets face it, that means AFM and usually injectors as well - then its time you also pony up for some better management rather than signal benders like the S-AFC/ITC and so on.
standard turbos wont make 200rwkw on all cars and all dynos.
best option would be a nistuned z32 ecu
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast and very unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If I lie about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley has terrible reviews but @Duncan made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
