Nissan Stagea Autech 260rs
1998 model
Imported just over 2 years ago as an auction grade 4 car. Have sheet and documents.
Still had boost restrictor in when it arrived, 100% original. 91K genuine km with proof.
Modifications
Steel wheel turbos, new gaskets, washers etc
100k service done
Adjust cam gears dialled in by envy
Power fc + controller tuned by envy imports
Trust cat back exhaust
Front pipe
Hi flow cat
Profec b boost controller
Apexi mech boost gauge
Endless sss pads
New battery few weeks ago
Autowatch alarm/imob
Series 2 tail lights
Clear front and side indicators
Just done 5K service
Body and interior are in excellent condition
134k km
Car made 254awkw on envy dyno
Car only run on ultimate or optimax as per usual. Always replaced oil and filter every 5000k with either royal purple or motul 300. Prob a bit more I forgot but buyer will not be disappointed.
Call Ben 0438 872 169
Edited by cefiro
https://www.sau.com.au/forums/topic/311285-nissan-autech-stagea-260rs/
  • 7 months later...
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
