ok so here's the deal, i bought a car in Japland, R32 GTS-t, has a BNR32 Rb26 in it, and according to auction sheet, a T78 turbo, assuming a 33D going by what they sell. Now internals are unknown, but seeing as nothing was listed, im assuming stock.
My first question is, is there any possible reason i should keep the T78 if i dont plan on fully building the engine? it will be used mostly for drift, so heaps of power isnt really needed hugely, but also some time attack, so extra power would come in handy.
My 2nd is, what kind of turbo from Greddy's lineup would be more suited to my goals of say a reliable 300rwkw, that would fit on the kit these come with (exh. manifold etc)? i'm not a low down torque hunter, so im not interested in chasing that 100rpm of less lag. i just want something that will provide usable power without having to change everything else around.
cheers
https://www.sau.com.au/forums/topic/311305-t78-on-internally-standard-rb26/
btw, mods:
Trust T78-33D
PowerFC w/Commander
HKS EVC4
Trust Manifold
Trust External Gate
Tomei Type-R Poncam
SARD Injectors
Adjustable type fuel regulator
HKS Pod Filters
Z32 twin AFM's
Trust Intercooler
Trust Oil Cooler
3-Layer Copper Radiator
Low temperature Thermostat
Turbo Back Exhaust
and before anyone asks, these are as detailed as they get for now, going off translated for sale ad.
it doesnt make sense, you say you want it for drift (small turbo) then you say you want not heaps of power (small turbo) then you say time attack (big turbo) then you say extra power come in handy (big turbo). which one do you want? it would seem odd to fit a T78 to a std engine, you certianly could do it, but why would you bother?
with bog stock everything you would be lucky to tune it at 12psi and not max everything out - aka pointless
wait till the car comes over and then check it out
if its got all the suppporting stuff on it, sell the T78 and get a mid sized hks GT28x/30x series and away you go, even a pair of GT-SS would be fine
but as its already in single mode, its probably cheaper to keep it in single mode
honestly didnt think it would be that hard to decode roughly what power area i was aiming for lol
i have it here in Japan, unfortunately i dont have the time or tools to do much snooping around on it for a few weeks til im in Osaka where i will have access to some decent shops.
as i mentioned, i would prefer to keep with something that fits the current manifold to make it an easier job, i have nfi what will fit or not (whether it's a universal flange size that HKS shit will fit on etc), i just dont care enough about turbos to carry any knowledge about them haha
I'm assuming from you post that its not yet in your posession, hence the sort of speculative question? :)
Throw it on the road..... once you open it up you'll realise that you won't want to replace it with anything else :)
If insane horsepower isn't quite what you were looking for, you 'll pretty much need to go outside the TRUST stable of turbos to find something suitable. A GT35 would fit the bill in terms of reducing lag and providing similar power levels (though you could consider a GT30 the next size down if need be).
ahk so are we talking all new kit to switch tables to HKS gear?
i have the car here, have driven it etc, currently running about 0.8bar but that's mainly due to me having nfi how to get the EVC working lol
the other problem is not knowing it's current tune, or model/condition of fuel pump. it's quiet most of the time, only occasionally making a buzz, certainly nothing like what i'd expect from something of a suitable size, the 040 in my 4dr at home is always buzzing in the background of a noticeable noise level.
Pretty sure Greddy/Trust use a different type of flange than garrett/hks turbos on their manifolds.
If you want 300kw look at the Trust TD06-25g with 10cm rear housing or larger
http://www.trust-power.com/02turbo/turbo_charger.html
edit: found a photo of the design of the turbo; see different style flange
Edited by Kaido_RR
RB26s beg for a big turbo, don't go down the TD route :)
Silent fuel pump dosen't nessicarily mean isn't a big one - have had dual in-tank pumps or single 044 which when mounted correctly are completely silent.
Your best bet is to get it your nearest Dyno & with all the appropriate gear and see how it goes..... you'll be able to touch up the tune / ensure fuel pressure is appropriate and then have all the fact to be able make a call on if you need to change the setup.
i agree,
i don't see why they would be running a t78 with aftermarket injectors but stock pump.
yeh definitely, unfortunately there is dick all in Nagano as far as car tuning goes so will have to wait for Osaka.
I agree, throw it on the dyno and see how it goes. If it makes good power on the dyno drive it for a while and see what you think. No point spending heaps of cash before you even know what you have.
Please dont get anything smaller than a GT35.
I think you mean 340-350rwkw not just 300 :)
t78 on a well set up GTR is one of my 1st choices. Drive it before you think about changing it. The fastest circuit car ive been in is the signal R34 with T88 and it was driven to and from the track and used daily.... it all comes down to setup.
I love my T88, T78 would be good as well.
Open her up on the highway, make sure its not missing and isn't hesitating when you're going WOT.
Also look out for boost creeping / spiking as well, but if you're only running 0.8 bar thats barely getting into the T78.
I'd just take it easy... stock fuel pump is very strange, it may have a sard intank, they are quiet as all hell and a very popular choice with the sort of setup you have.
To be honest i'd just take it easy until you get a dyno run and have a look at how the AFR's are going, also you mentioned you have a power FC with commander? give the car full boot and have a look at the Duty Cycle, you don't want to be going over 85%.
slight hesitation sometimes when it gets to around 6k, but generally pretty smooth. inj duty cycle averages around 75% before i back off, yet to see it break into the 80's
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
