Search the NA forum for what mods to look at doing (intake, extractors, exhaust, etc) & what sort of power figures these mods will give but if staying non-turbo expect to spend a lot of money for very little gain... For the price of a set of extractors & an exhaust you could probably buy & install all the bits to bolt a standard RB25 turbo setup (manifold, turbo, lines, dump, cooler, etc) to your engine & make a lot more power. One thing you will have if you stick with the NA setup is nice sharp throttle response but that probably wont keep you entertained for long....
On another note, I may be way off here, but I'm sort of assuming you could be a P-plater, hence the non-turbo?
If so, depending on what state you're in you could find that ANY performance modifications are forbidden, making your modified non-turbo just as illegal for you as a turbo model with twice the power.
As long as you realise you will never have the same potential as a turbo engine & you are happy with that, go for it.
Would love to build a fully worked, hi-comp NA one day, for mentioned response, etc. But just too addicted to boost!
mate as said before you will get fark all out of an N/A so whilst on ur p's start smart modding and mod what can later be kept when u turbo it..
but heres a quick guide... http://www.skylinesaustralia.com/forums/Po...sp-t194033.html thers a sticky in this section no need for another thread... read my friend!!
enjoy :)
Edited by noely1
ok im gona break it down nice and simple for ya.
DO NOT WASTE MONEY SAVE FOR TURBO / WAIT TILL OFF Ps
but i know its hard to do so when young / on Ps (personal experience)
1. Exhaust 2.5" catback + extractors if you want them..
2. Pod filter / heat shield
3. Cut hole / feed a cold air intake
4. Get a nice body kit if you want.
5. Wait till your off Ps
Mines pulling 123rwkw with just a cat back / pod. Helps to have a healthy engine. Also manual.
exactly, i wouldnt count chucking a cat back / pod wasting money really considering its only like $500 and most people want a nice car sound anyways.. but i mean any other mod like injectors / fuel pump / cam gears tune or what ever is just a waste. I just have a cat back and waiting a few more months for a GTR
edit: yeh that link is just a example of a healthy engine with just exhaust and pod.
first of all piss off the auto,
then get exhaust and extractors theyre not that dear, shop around a bit
set of light weight racing wheels, expensive but atleast you can put them on any car regardless of turbo or non turbo.
then get a decent tune or remap and then you will be keeping up with stock turbos
yeah that true mate i think i will just wait till of the P's. Thanks for advice might just make it look nice
The best thing you can do to your non turbo engie being a P plater is go out and get some essentials (carby cleaner-throttle body cleaner, lube spray, electrical connector and wire cleaner, WD40, Wire dryer ETC ETC ETC)
Buy some automotive tools if you dont have some etc etc
-Change air filter
-Change oil filter
-Change fuel filter
-Change engine oil with an oil flush (try changing to a full synthetic such as nulon which is about $150 less than a redline oil usually $50 at automotive stores)
-Change gearbox oil
-Change diff oil
-Change brake oil
-Change Clutch oil
-Change coolant with a system flush before
-Total fuel system cleaner is 28 times more concentrated than a injector cleaner so spend your money there and it will do the best job on the place you cant reach without pulling an engine apart
-Clean throttle body (spray the hell out of it with carby cleaner and wipe down)
-Clean the AAC (IACV) (spray the hell out of it with carby cleaner and wipe down)
-Clean the Cold start valve
-Change sparkplugs
-Go around and pull all your electrical plugs out, from headlights and brake lights - throttle position sensor and O2 sensor. Clean all conections with an electrical contact cleaner and wire cleaner on the wires in the engine bay such as earth wires (will be very time consuming :( )
-Clean all sensors E.G. your radiator sensors may be gooped up if oil has ever come into contact with the coolant, O2 sensor can become conjested with carbon so carby cleaner can get rid of that
-Change all your relays and fuses that are not working (using a test light you will see if there is a current passing through or not)
-Test all your sensors with a multimeter providing you know what volts, resistance etc you are looking for. This will determine if any sensors are dead or not up to scratch (Read next line for other option)
-You can also have Nissan diagnostics scan tool pluged into your car (or even buy the CD and plug online) too read out any errors that may be present and you can also have your timing set, air/fuel ratio mixtures adjusted and a few more things (this is best as it will read all sensors too and give accurate readings). This test is really the last thing you will have too do as it will read your whole car and you will be able too tell things like the volts in your battery or even shut down the spark too a cylinder. When it reads 'error code: 58' you dont have any errors in your car and its running fine.
Once all that is done if you are getting the ECU scaned the tool can reset it. Once reset take it out for a nice calm drive and it will load all information from the car back up onto itself. The car will feel new and will definatly give you some power back, hopefuly get you all the way too stock power output :O
All up you could spend $500 here depending on what tools, etc etc, inc the Nissan diagnostics scan tool which is about $250 or you can get it done at a performance shop.
Oils and filters and spark plugs are common things and you wont pay more than $400-500 if you buy all you aerosols and oils from nulon.
And asuming you do all the cleaning and (all this is very easy and a w/e can be the best time to complete all this) taking apart of small electricals and parts you will be doing labour youself. I can see it cost all up $500-$1000
THIS IS THE BEST THING YOU CAN DO TOO YOUR NA!!!!!!!!!! so much easier than a turbo and you will gain power and also piece of mind that your car it a lot more reliable......
