I found out about a Datsun cruise that was on sunday last week. Just a BBQ down at Cordeaux Dam, and a few of the members to show others their pride and joy's.
As you can guess, the quality of the cars was fantastic.
here is a shot of some of them...
And that silver one is a SSS Bluebird
https://www.sau.com.au/forums/topic/311375-datsun-cruise/
Steve,
You need to be a member of a club that has historic rego (sydney datsun club for example)
car has to be standard, or have periodic mods. eg - cant have an SR20DET powered 1600 on club plates in NSW but can have mini lite wheels
very cheap - rego/ctp is cheap and ctp is included in the rego. comprehensive insurance is bloody cheap too
car has to be 30 years old
can only come out for club events (average once a month) or if you have permission from club tresurer.
hope this helps!
https://www.sau.com.au/forums/topic/311375-datsun-cruise/#findComment-5126342
SAU NSW will be able to offer historic rego in the next few months too :(
won't be long until we can cruise putty rd in r32 gtrs on historic rego :worship: but there are plenty of club member cars over 30 years old already....1980 and later....
https://www.sau.com.au/forums/topic/311375-datsun-cruise/#findComment-5131393
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
    • I just try to entirely stay away from ladder now unless it's something basic maintained by electricians. Even then and to your point, it mostly ends up being blocks I wrote in structured text.  PLC's are slowly going towards C, C++ and C#. I just wish Allen-Bradley would jump on the bandwagon.
    • All of them are missing. You do not get much done with just AND, OR and NOT unfortunately. Ecumaster for example has a text based editor with at least 60+ math and logic instructions.
