Vehicle 1997 TOYOTA CHASER JZX100 V
Price $23,000*
Interior Colour Blue
Kilometres 136,000
Colour Pearl White
Transmission 5 speed Manual
Body 4 door 5 seat SEDAN
Brief Comments 1997 JZX100 Mark II - Tourer V ,**Factory 5 speed manual**. 215rwkw, Neatly modified Mature owner
comments
* 1997 JZX100 Mark II - Tourer V
1JZ-GTE VVT-i - 136xxx genuine kms (Two owners in Japan)
Factory option pearl white
No accident history
Major 100k service done. (timing belt/waterpump/bearings)
This is one of only a few factory manual Mark II's in OZ, 95% were Auto's from Factory
-Climate control (freezing air con)
-Central locking (auto locks at 20km)
-Boot release on key
-Traction control & snow mode
-Factory carbon fibre centre console & other surrounds
-Driver, passenger & side airbags
-Electric lumbar support on drivers seat
-Factory 7 speaker stereo
-ABS brakes
-Vanity mirror with light (passenger side)
After Market parts include:
Performance:
-Apexi 3.5" exhaust
-Apexi pod filter
-AM Performance 3" screamer/dump pipe/front pipe
-cold air Intake
-Jap spec earthing kit
-Apexi front strut brace
-Tein HR driving master coilovers
-TRD 2-way *NEW* $2500 done 1000km
-Extreme Drift clutch pressure plate and HD Flywheel all *NEW* 1000km
-Project Mu brake pads all round
-Under car brace
-HKs Boss kit and deep dish wheel
-Kazama shifter
-TRD Air bag Canceler
other bits:
-Work VS-KF wheels 18 x 8 front and 18 x 9.5 with new rubber TOYO proxis 4's
-Genuine Car Make T&E Vertex body kit (4 piece kit with all serial numbers *just respayed*
-Factory HID's & foglights Now with japanese CATZ upgraded globes $800 the set
-All 5 Factory "Tourer" floor mats
-Brand new wheels studs all round
-Kenwood Mp3,USB bluetooth deck with handsfree calling
-Dark tint on rear half of car
may have missed a few things.....
some Info:
just serviced and changed 136000km:
-Motul 300v chrono oil 5.4L + liquid molly Engine protect
-Motul 660 High temp brake/clutch
-Motul Comp 75/140 diff
-Motul comp 75/90 Gearbox
-Motul Dex lll pwr steer
-Toyota coolant Pre-mix + Motul Mocool additive
-Toyota Iridium plugs
-Toyota top tank
serviced every 3000kms
PRICE NEG! on removal of parts
Stock Parts included in sale! 3 months REG
Price $23,000*
contact:Alex 0421340064
Edited by PSYKO
Price $23,000*
Kilometres 136,000
Colour Pearl White
Swap my r34 4 door manual 0405515388 if interested
comments
No accident history
-ABS brakes
Performance:
-Apexi 3.5" exhaust
-Apexi pod filter
-cold air Intake
-Under car brace
-Kazama shifter
other bits:
some Info:
-Toyota top tank
Price $23,000*
mate you and the missus (? with the 180) maintain your cars real well...they both seem quite clean.
well done.
free bump
Cheers mate lol yes I maintain them both lol overly cared for. Only the best of everything
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
