  • 1 month later...
  • Replies 48
Aiming for 250-280rwkw in a R33 gtst. (currently got around 200rwkw)
Will the R32 GTR fuel pump be good enough for this goal?
Is $125 a good price for a 2nd hand one?
thnx.
Currently have 265 rwkw using GTR pump, so should be OK.
Ok price:cheers:
at what point on a gts-t will the fuel pump need to be upgraded, and from there the injectors and regulator ???
i was wondering the same thing actually...benm said they are good for 300bhp or approx 180rwkw when this thread was started way back in the day...
i originally thought it was closer to 200rwkw or thereabouts many go over 180rwkw with the stock gtst pump and still get enough fuel...Could people with experience in this matter please confirm for me as currently with the 180rwkw fuel pump limit it means i will be close to or on the limit next week when it gets tuned for some more power. Just wondering if i should start thinking new fuel pump??
There is no absolute answer, it's not like a light switch, OK at 180 rwkw and not OK at 181 rwkw. It depends on soooooo many factors, how clean is the fuel filter, what voltage is the fuel pump seeing (do you have a big stereo that sucks power and lowers the voltage), have you improved the efficiency (cams for example) that mean you get more power out of each molecule of fuel, how good is the ring to bore seal, are the injectors clean )hows there spray pattern), how efficient is the turbo, the intercooler, the exhaust etc etc
So some people get 200 rwkw and some don't, and that's as good an answer as I can give:cheers:
Hi gtsii
I recently purchased a 044 for $360 brand new COD from an advertiser in these forums.
We installed it intank which was a bugger of a job - if I did it again I'd seriously consider mounting it externally - so much easier but I'm unsure on the legalities.
Make sure you install the check valve also as we didn't and it takes two clicks of the key to prime the fuel system enough to start in the morning.
It's nice and quiet though - certainly worth doing the job once and properly. Petrol stinks.
Good luck!
Glen
same reason i like the gtr pumps, straight fit and are quieter than the bosch's.
You can get them second hand or there's a place in Vic which sells them brand new for $440 each. I'm getting one and I think if we were to get them together we might be able to get them cheaper.
pm me if interested! :)
  • 5 months later...
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
