I have been chasing a set of replacement copper plugs to try with the E85 im about to be running, Apparently the iridium plugs can glow causing pre-ignition. I found the STI's are running similar plugs and they had this list on their forum.
LFR6AP-9 OEM nm35 Stagea (Platinum)
IKH22 5345 Denso equiv. (Im running these at the moment.)
STI List:
NGK IFLR6B (Iridium)--Subaru STI OEM Plug
NGK PLFR6-11 (Platinum)
NGK LFR6AIX-11 (Iridium IX)
NGK LFR7AIX-11 (Iridium IX)--"one step colder"
NGK LFR6A-11 (Copper)
Denso IKH20 (Iridium)
Denso IKH22 (Iridium)--"one step colder"
I still havent worked out what heat range I should be going for, colder if there is pre-ignition, hotter if I have cold start problems from what I have read. Any plug experts around?
Edited by scotty nm35
https://www.sau.com.au/forums/topic/311431-m35-plug-replacement/
thats basically it. something else to think about, if your using too cold of a plug they will foul up quickly. the plugs have a kind of "self clean", to help with soot build up on the electrode. this process wont work as good if a plug that is too cold for your application is used.
i have no idea about what is required for E85, have you looked in the FI section, i've seen a few topics come up about E85?
i've only really used NGK plugs, and can help you out with their part numbers. i have a chart i use that i found on the breakdown of the part numbers you may be interested in. its a few post down in this thread LINK
  • 4 years later...
Hi, I know this is an old thread but I wanted put these plugs out there to see if anyone has tried them.
Brisk ER14YS
They use a silver electrode and are rated for 45k kms, and the 14 is the same as a 7 heat range for the NGK plugs or 22 for the Denso's. And they seem to be popular with the EVO IX crowd.
Thanks,
Grant.
I had a lot of issues running the Denso's, to the extent they completely melted in 10,000k's (although I am pushing things hard.) The stainless threads also seize up in the thread easily without some antisieze on them. They are rated to 160,000 but obviously aren't that good for turbo applications.
I am sure anything will run fine as the stock coils throw a fair spark, but I stick to the NGK's these days, LFR7AIX, due to them lasting so much longer. For $15 a plug it just isn't worth changing them any more often than you have to.
The Evo crowd isn't the smartest... I know this well, as I have a 7. :P
  • Like 1
    • I've watched some vids and the technique seems to be to butt the sheets up to one another and use MIG to spot weld and slowly fill in the spots until its eventually all sealed. No runs as you would normally do, as there's too much heat generated that way. Yeah my stick welds are terrible these days because its been so long since i've done any of it. I expect to be spending many hours practicing
    • I have personally seen a Tomei USA RB26 cam that didn't even fit the head. Kind of nuts to me that it was even possible for that to happen but such is life.  There's two UP Garages in the US. One is a US branch of the Japanese company which sells things they brought over at tremendous markup. The other is University Place Garage/Fairlady Motors which is a shop best known for putting VCAM in RBs and trying to convince people to stop putting in 800hp of turbo on a 2.5L motor.
    • Gasless MIG is not exactly suited to what I would call "delicate" or "attractive" welding. So I would rule it out for sheet metal rust repair type stuff, unless you're only doing it in hidden places. I'm thinking about getting myself a gasless MIG for "hack together" type work. Noting that my welding experience is very very low, and quite a long time ago. So I'm also looking for "simple", but I'm not expecting "excellent". I'm not even sure that proper MIG is the best for sheet metal work. I get the feeling that the degree of control and the minimisation of heat input that you get from TIG is probably what you really want. And then you have to get good at doing it before the welds won't look like a monkey flinging a handful of shit anyway. You're probably SOL for an easy and cheap way to get from where you are to where you want to be. Much like myself.
    • Any recommendations for what would be the easiest welding type to start on, for sheet metal rust repairs and maybe some exhaust piping too? Seems like MIG is the most common. Would gasless MIG be ok to learn on and do some simple jobs? I have a stick welder which has a Lift TIG setting, but i'm more interested in getting whatever's easiest to do, and most suitable, rather than using what i have.
    • Is the UP Garage in the US of Ayyeee even the real UP Garage?
