This is interesting. I have no powerduct, but I did run for a few months with the little panel on the airbox removed. Not sure how much difference the powerduct would make vs not having anything there. The airbox sits so close to the front that I figured the only difference would be that it might suck in hot air when I wasn't moving, but in theory that should be better for fuel economy, not worse.
Recently I put the little plastic panel back on and realised the difference it made. With the panel back on again, I now have much better low-end response, smoother power delivery and the car feels noticeably faster. Fuel economy also seems to have improved a little, but not by enough to make any great claims about it. The main difference was in the ability to build boost at low revs...it seems having the airbox closed is good for building boost pressure early.
Top end performance was definitely improved with the panel removed, so I may have had a heavier right foot more often...
hmm... I put a Powerduct on last weekend and noticed an improvement in responsiveness almost straight away (my CAI has been disconnected until I make a new one that fits with the front bar). The difference was like trying to suck air in with your hand over your mouth (closed airbox and only stock funnel) as opposed to just breathing normally (with Powerduct).
Didn't really notice any additional sound although it may be a bit difficult to hear over my turbo and exhaust :banana:
The engine does seem to have a bit more of a sense of urgency about it with the duct on.
To each their own I guess, but the thinking that turbo cars need as much air to the intake as possible would make you think that the Powerduct would be more a positive than a negative for our cars, no?
I don't see either how by limiting air intake it could make the turbo spool any earlier.
It is hard to imaging how it could help low down power but perhaps it is like the opposite of a restrictive exhaust on a NA car where that helps torque.
From memory it is just a small difference anyway but I kept mine off as I liked the feeling it made to the power delivery at the top end.
Cheers
Andy
I dont understand why mine felt faster when I put the little panel back on. I cant explain it. But it definitely does seem faster or at least more responsive off the line now. It doesn't make sense...
There must be a reason why Nissan included the powerduct with all n/a versions of these engines and not with the turbo version.
emissions
  • 1 year later...
going to reactivate this thread.. hoping someone has worked out something to fix the fuel gauge.. mine is shocking can jump a quarter of a tank between starts.. i am on gas though like to keep at least a 1/3 in the tank.. though every few days it says i am near empty..
anyone got a fix?
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
