Bobjones Posted January 5, 2004 Share Posted January 5, 2004 I have heard this is a common problem with R33's. That the rear gearbox mount breaks or shits itself or whatever and there is a slight knock when changing gears. Can anyone lend some light on this and if I can change it myself??? Part number if I have to get it from Ni$$an??? Or if I am parking up the wronmg tree any help would be good, I have done a search on this but I want to be certain, as it only happens sometimes when going from 1st to 2nd and not necessarily at high rpm...occurs some times at 3-4k... Thanks in advance Neill Link to comment https://www.sau.com.au/forums/topic/31144-gearbox-knocking-going-from-1st-to-2nd/ Share on other sites More sharing options...
wrxhoon Posted January 5, 2004 Share Posted January 5, 2004 if it does it when droping the clutch ( like a thumping noise ) it may be the mount . its easy to check , have a look its on the crossmember , if u cant see take the crossmember off its only about 8 bolts but u have to suport the box . as for the price not sure but it wont be cheap , check with nissan . Link to comment https://www.sau.com.au/forums/topic/31144-gearbox-knocking-going-from-1st-to-2nd/#findComment-628953 Share on other sites More sharing options...
