Im currently re-doing every hose in my rb25 s13 with speedflow 100 series, Just wondering How it holds up with unleaded fuel as it says in the speedflow catalogue that its not suitable for fuel. I see heaps of fuel systems with surge tanks and inline pumps running 100 series, Anybody had any dramas with it?
Thanks
https://www.sau.com.au/forums/topic/311440-speedflow-100-series-with-unleaded/
Thanks
It's fine for unleaded but it will smell. Teflon braid (200 series) is the best for fuels, especially when used inside the car.
straight off speedflow's site...
100 Series
Uses: Fuel Systems, Coolant Systems & Oil Pressure Systems.
Compatibility: Methanol, Water, Oil & Unleaded Fuel (see note below).
Restrictions: Not recommended for use in confined areas with unleaded fuels due to permeation of fuel vapors.
Not to be used with brake fluids.
Not recommended for use around extreme heat sources such as turbo’s.
    • Hi all. So one of my major issues at the moment is my rear turbo leaking oil on the exhaust (and the general area). I presumed it was the rock hard super old drain hose, which it was not. So now I am in the midst of removing the rear turbo to get access to the banjo bolt that goes into the turbo oil feed. As one of the previous owners accidentally? tore off the OEM oil feed hardline that reaches behind the turbo, they ran braided lines directly to the turbo, presumably PTFE. Now, regardless if the line has rubber or teflon inside, is it just generally a bad idea to do this? I imagine these lines get quite hot being between the engine, turbo core and exhaust manifold. I suppose it's not too far fetched to think the line may even have melted. I'd love to hear your opinions on this as as the replacement OEM hardline piece is 130 per unit. And cutting open the currently mounted line to see inside will mean I just have to get a replacement either way. So far I am hoping maybe the bolt just loosened or (god forbid) they forgot one of the crush washers.
    • If it's a factory 20de manual probably has the 6 bolt flywheel in which case the det clutches won't work as they're 9 bolt.
    • All RB push clutches are interchangeable. AFAIK, the 4cyl ones are not. Different flywheels. The RB small box is not identical to the 4cyl boxes. Just very similar.
    • Hi. I need a new clutch for my gearbox. It is a factory smallbox behind RB20DE NEO. What options do i have? If iam not mistaken the gearbox should be the same as in R32 GTST and Nissan S14/S15? I found some Xtreme Clutch Stage 1 for S14/S14 (i dont know if you know the brand) (UK) OR...is the clutch same as in the bigbox from RB25DET?   Thank you!
    • Listening to an artist called "the flashbulb". Not bad. Makes some fairly well researched youtube vids in various things.
